My cars never had trouble starting untill the day before yesterday i pulled it out the garage and i couldnt start it to get it back in so had to roll it back in
first thing i checked was for spark on the plugs and that was fine
second was the tdc and there was a little burn on the one wire so tapped that up
third was the relay in the scuttle panel and then the fuel pump relay under the passenger side footwell there was a burn mark on the plug and also inside the relay on the back of the board but i thought this was fine as i could still hear the fuel pump priming when cranking the engine over
I then checked for fuel i pulled the main pipe off the carb and cranked the engine bone dry i then pulled the pipe off the fuel filter and cranked engine to see if it was the fuel regulator or the pipes upto it no fuel.
pulled the fuel filter off and cranked again still no petrol i then swapped the fuel pump and with another one still no fuel also checked both pumps with jump leads and they both spin up
any ideas guys???????
