Results 1 to 20 of 20
    hasselt-belgium
    Gt2560r on c1j?
    I've been offered a nice deal on a new gt2560r here are the specs i got.
    Compressor 60mm, 60 trim, 0.60 a/r . Turbine 53mm, 62 trim, 0.64 a/r
    Wondering what this turbo would be like on a c1j. I'm running piper 285 and efi and i want to have it remapped to run 1,8bar.
    Non-member rs250nut's Avatar
    Re: Gt2560r on c1j?
    I think Brigsy has one of these on his van, not sure he may have a bigger turbine housing than the 64, all depends what you want the car for. I doubt you would have much boost before 4000rpm
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Gt2560r on c1j?
    Have you been offered just one turbo or can you get them cheap from a dealer? If so how much
    hasselt-belgium
    Re: Gt2560r on c1j?
    Sorry mate just one. He bought this for a gtt but never fitted it.
    I dont mind some lag but no more then the t28 im running at the moment.
    Re: Gt2560r on c1j?
    Size wise it looks like the same as a 200sx t28 which gets going at 3000rpm on the b18ft so 4-4500 sounds about right on a c1j.
    Re: Gt2560r on c1j?
    I have one with .64 rear, spools up quite well full boost 4.5-5k. I do have surge issues at higher boost levels though
    Non-member Coops's Avatar
    Re: Gt2560r on c1j?
    I have similar trim on my GT28RS and it spools at about 3500, but that's on a F7P lump, I would of thought it'd be laggier on a smaller engine such as the C1J.
    if the deals right though i'd plug for it ;-)
    Non-member SirSamuelOfBuca's Avatar
    Jan 2012
    Whittington
    Re: Gt2560r on c1j?
    mines on the c1j and spools at 3500 as well. Ill double check at lunch time though!
    hasselt-belgium
    Re: Gt2560r on c1j?
    Wow cheers for the replys will have a look at the vids when i get home brigsy. Im @ work on my phone and there is lots of noise. Love those turbod vans. We also used to have one with gtt lump.
    Sirsam... Did you check when yours comes in. Would be great at 3500 but im not hoping to much...
    For the moment ive got some chinaturbo on there of unknown specs so i called my friend and said ill take the gt2560.
    Jan 2012
    Whittington
    Re: Gt2560r on c1j?
    Ye gave it a blast to tesco at lunch 3500. It does spool a bit before then but 3500 is when it pulls like a beast
    hasselt-belgium
    Re: Gt2560r on c1j?
    That sounds excellent! The one ive got now is also laggy or maby its dead...
    On the other hand i bought a williams last weekend wich i wasnt going to turbo but iff it the turbo wouldnt be good for my 5 i still have a second option since i still have so many turbomanifolds laying around wich i still havent ebayd.
    Re: Gt2560r on c1j?
    Quote Originally Posted by SirSamuelOfBuca View Post
    Cant be a .64 rear mate, mine makes boost from about 3k but nothing useable under 4.5k.
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Re: Gt2560r on c1j?
    3500 sounds like a .49, mines similar.
    Re: Gt2560r on c1j?
    My old gt2554r with .49 turbine housing used to come on boost around 3500 and on full chat around 4200-4300. If I did it all again with a c1j I would go with a bigger rear housing and a big ass cam, who gives a $hit about lag, just rev it harder
    Re: Gt2560r on c1j?
    My exact thoughts Jon, if i can sniff out an .86 rear to fit mine it will be going on!!
    Re: Gt2560r on c1j?
    Makes sence, more power per pound of boost, just moving the powerband up the rev range.
    Ivybridge
    Re: Gt2560r on c1j?
    Have you still got the .49 rear housing mate?
    Re: Gt2560r on c1j?
    I'm affraid I dont mate but I know where I could get you one from if you need it, have a chat with cr turbos in New Milton sound bloke and one of the only people I know who can supppy a Gt2554r with a .49 rear housing, they have them cast themselves.
    Ivybridge
