as above what is the settings and sequence please for the c1j, any pics or diagram as ive lost my haynes manual and i cant be bothered to go and buy another
I always did mine 20/20 matey and it's rule of 9 matey
go opposites, so no8 valve spring compressed and adjust 1, 7-2, 6-3, 5-4 etc
Here is links to an online haynes. Many thanks to James5 who sent me these links a cppl of years ago
http://www.scribd.com/doc/9607384/Renau ... r-1-Engine
http://www.scribd.com/doc/9607419/Renau ... ing-System
http://www.scribd.com/doc/9607486/Renau ... st-Systems
http://www.scribd.com/doc/9607507/Renau ... ion-System
http://www.scribd.com/doc/9607520/Renau ... r-5-Clutch
http://www.scribd.com/doc/9607532/Renau ... ansmission
http://www.scribd.com/doc/9607538/Renau ... ive-Shafts
http://www.scribd.com/doc/9607609/Renau ... ing-System
http://www.scribd.com/doc/9607661/Renau ... n-Steering
http://www.scribd.com/doc/9607743/Renau ... k-Fittings
http://www.scribd.com/doc/9607831/Renau ... cal-System
http://www.scribd.com/doc/9607884/Renau ... Supplement
http://www.scribd.com/doc/9607994/Renau ... -Continued
http://www.scribd.com/doc/9608043/Renau ... g-Diagrams
edit: 1. 23 for the valve clearance section
I don't think that's an "on-line Haynes" but someone has scanned and posted illegally, ie, Haynes could sue them.
ooops!!
shall I delete my post?
What cam??
Use the rule of nine. If number one is open adjust number eight and so on
If its a piper 285 go .20/.20 matey, for a 270 probably .15in/.20 ex as per standard
i always set tappets up what i know as rocking so get 1 and 2 fully down rocking then adjust 7 and 8 to the setting needed, so adjusting 2 rockers a time its a little quicker
The piper 270 is something like 25 inlet 30 exhaust. I set mine to 15 and 20 originally but then read the spec and adjusted them. I know they were random values that you set them too.
Part No. Application Power Band Power Increase Duration Valve Lift Timing Full Lift Lift @ TDC with clearance Valve Clearance
Inl Exh Inl Exh Inl ATDC Exh BTDC Inl Exh
R5TBP270 FAST ROAD 2000‑6000 15BHP 260° 260°
0.342″
8.69mm
0.342″
8.69mm
20‑60
60‑20
110°
0.026″
0.66mm
0.024″
0.61mm
0.010″ / 0.25mm
0.012″ / 0.30mm
285 is 25 and 25
so 25, 30 then, where yours quiet like this?
