Results 1 to 14 of 14
    Non-member TrixNFlix's Avatar
    Preston
    Clio 182
    Well a friends just had his dephaser pulley and cambelt changed, due to a misunderstanding he didn't change the auxillery belt. On full lock it's started squealing, how do I tighten it up, any guides for this and pics of doing the cambelt as I quite fancy one of these too!
    It's a full fat Clio 182. Cheers guys and gals.
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: Clio 182
    You can't tighten the aux belt, its tensioned by a spring loaded damper... If thats the right name for it..?
    Non-member Nick k's Avatar
    Leicester
    Re: Clio 182
    Doing the cam belt is a complete Tw*T The aux belt uses a tensioner arm pulley affair that cant be adjusted, you can get a aux belt kit from renault for about £85 that comes with the belt, bottom metal roller and tensioner arm thing. If its making noise then the belt is more that likely dead.
    Leicester
    Re: Clio 182
    Ashy has a pdf guide thing about the cam belt change, im sure a link will appear to it
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: Clio 182
    Quote Originally Posted by Nick k View Post
    Doing the cam belt is a complete Tw*T .
    Couldn't put it better myself... Done it once on a 182 and its not something I'd want to do again...
    Taaaa daaaaaa
    Preston
    Re: Clio 182
    thought so, told him to get the auxilery kit while he was getting the dephaser and belt done but he got his wires crossed and thought it came in the cambelt kit from Reno! What are his options guys, just sequels with the car stationary on full lock. Can it be done on its own?
    Preston
    Re: Clio 182
    Top work you guys nice link
    Leicester
    Re: Clio 182
    Yea the aux kit is not too bad to do, its engine mount off to get to the arm thingy, bottom roller i have to grind a 13mm 1/4 socket down to nothing to get it on the bolt between it and the inner wing but its possible. ENJOY
    norwich
    Re: Clio 182
    Silly question but are you sure its the belt making the noise and not due to low power steering fluid?
    Non-member markey b's Avatar
    Bury St Edmunds
    Re: Clio 182
    aux belt is a routine service item at 32k iirc
    Preston
    Re: Clio 182
    Quote Originally Posted by TNT Tricky Nicky View Post
    Yeah that what I thought it was at first as it was at min level, topped it up then still made the same horrible noise, investigated further visibly and noticed the belt slipping on the power steering pump pulley when getting full lock while stationary. Do the automatic tensioners often fail, can I get away with just putting a new belt on?
    Preston
    Re: Clio 182
    Thought it was originally 72k, then got shifted to 36k after problems with them snapping. Consequently the millage is on 96k with a stamp for cambelt and aux belt at 72k.
    Non-member Hoolio's Avatar
    Wallingford
    Re: Clio 182
    You should really fit a new kit along with the Aux belt every three yrs or 36k.
    Non-member 5teve L's Avatar
    RH12
    Re: Clio 182
    Hardest part I found was fitting the aux belt, I found the tensioner is a right pain to get to without the right tool, took me ages, cambelt was a piece of piss to do compared.
