Results 1 to 15 of 15
    Banned
    Feb 2011
    wont start
    Trying to start the 5 but it wont.
    igave it a try and nothing so took plugs out to check for spark and while doing this it started.put plug back in and went to start it again and nothing.
    it only seems to fire up when a plug is taken out.when i pyt them back in it wont fire up.
    any help would be great.
    cheers all
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    Re: wont start
    Dave, checked for fuel?
    Member Woznaldo's Avatar
    Canberra, Australia
    Re: wont start
    Does it turn over slowly with the spark plug in and quicker with the plug out? If so, it might just be the battery is low or the starter motor is on the way out.
    We need more info. When was it running last? Did it always start well before or has it been slowly getting worse? How much fuel in the tank?
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Re: wont start
    Could just be flooding the car, when uve taken the plugs out the unburnt fuel fouling the plugs may of evaporated then itll start
    Banned
    Feb 2011
    Re: wont start
    It was last running a couple of dsys ago.drove it back from the garage where it had a new clutch fitted.
    got it home and parked it up.went to it yesterday to take it for a run and would not start.theres half tank of petrol
    it does seem to turn faster with plug out. i tryed it 3 times with plug in and out and it fired up all 3 times when plug was out.
    ill bang the battery on charge and see if that sorts it...
    Cheers for all help chaps
    Banned
    Feb 2011
    Re: wont start
    Still having trouble with this.got fuel and spark.just wont fire up.
    bloody thing.
    hasselt-belgium
    Re: wont start
    Had the same problem once and changed the plugs for new ones and it fired up again. I guess i killed my plugs with the many starting and them getting wet...
    Just my 0,2
    Sep 2005
    Parkgate Cheshire
    Re: wont start
    how do you try to start it?, choke on? foot to floor? pump the accelerator? Does it sound like its turning quickly enough? does it start with a charger on? or jump leads from another car?
    Banned
    Feb 2011
    Re: wont start
    just tuning key with choke on.
    iv got a booster pack on the battery so its got plenty of kick and turns over fast.just wont fire but again it does when i take a plug out.
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: wont start
    Leave choke in and try. Have the garage fiddled with the carp at all? Idle mix etc...?
    Banned
    Feb 2011
    Re: wont start
    Dont think so mate.it was running fine untill i parked it up for a week.
    is it in or out to lean the mixture? i cant remember its been that long since i messed about with one.
    Sep 2005
    Parkgate Cheshire
    Re: wont start
    does it start if you disconnect a plug lead instead of whipping a plug out? if so then i think maybe the coils not able to build the charge up, but does when only firing 3?
    May 2012
    Re: wont start
    Im having the same problem, after standing for 2 weeks, waiting for a turbo rebuild.
    Should the fuel pump make a noise, when switched to position 2?
    I hear a click from a relay, which I presume is the fuel one.
    spark, not sure about fuel, will not start
    Drove it to the current location no problem, then turbo replaced, no start!
    Re: wont start
    The fuel pump doesnt prime on ignition, it only works when cranking. Have you disturbed the tdc lead when changing the turbo?
    May 2012
    Re: wont start
    Thought about the tdc lead, the previous owner had cut and spliced it a couple of times, so I repaired it yesterday with some soldering and new wires.
    Is the tdc sensor quite fragile?
    There is a spark, I only checked cylinder no 4 though.
