Broken my front wheelnut what's the bast way to extract it?? Need it out for bluntys dyno day.. Cheers guys
Drill down the centre of it then use some extractors to unscrew it back out. I had to do it a few months back.
Sorry I don't have an extractor. How can I get it out with basic tools like sticky back plastic and glue there must be a way? Cheers
Can you get the wheel off? If so I would weld a nut to it and remove like that. if not the above is probably the best way, no chance of getting an old socket on it?
I can get the wheel off but I don't have the tools really no welder no extractor.. Think I will have to take it to. A garage.. Cheers guys..
Is there any part of the bolt left, maybe try some m-grips, or has it snapped right to the hub?
If its flush there shouldn't be any strain on the bolt as its not
Holding anything on( unless you cross threaded it)
So get a centre dab / small chisel and hammer the bolt remains
As if your removing it (anticlockwise )
If it ain't. Crossed it will come out no probs
Just reach behind the hub, and undo it from the back with your fingers
Another way is to drill down the centre as mentioned
And if you've no easy outs hammer in an allenkey or torque bit them
Screw it out using that
It's still light out go to it now and let us know how you get on
Cheers guys I will have a go on Friday now as its the only time I have.
Do yourself a favour and order 16 new ones. Cost you under £20 and will replace your old tired ones.
If you get stuck mate give me a shout I have extractors and a welder
All sorted thanks to the help of r5turboron another great member met today cheers for that.. Great bunch of guys and thanks for all the advice from other members..
No problem mate nice meeting you
