Andrew Cooke
I don't know what you're trying to achieve, how much you want to spend, or what you have lying around, but don't write off dropping a turbo cam in if it's cheap enough. The standard NA cam is very mild (it is a shopping car, not a sports model), but if you're buying new get an NA cam cut rather than use a turbo one.
I'll bet a 285 turbo cam would work just fine as a fast road cam. But maybe if someone has a kent 200 ground at 106deg it would work better - and sound racier....
