Page 1 of 2 12 LastLast
Results 1 to 50 of 76
    Non-member GaryS's Avatar
    Fleet, Hampshire
    Questions
    where abouts on the manifold do you connect up the one way valve?
    i will have more questions to come yet people..........
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Questions
    For the brake servo? Take it from the plenum near the throttle body over the rocker cover.
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Re: Questions
    base of the carb to the brake servo.
    Non-member TrixNFlix's Avatar
    Preston
    Re: Questions
    We are efi baby!!
    Fleet, Hampshire
    Re: Questions
    We are efi baby!!
    I'm working on it
    Re: Questions
    Do you have the gtx with turbo conversion then matey?
    Sep 2005
    Parkgate Cheshire
    Re: Questions
    anywhere on the inlet manifold that sees vacuum then.
    Fleet, Hampshire
    Re: Questions
    The b18ft has just gone in and I've just started to plum her up so may need some more help soon
    Re: Questions
    Ok then its the take off near the throttle body over the rocker cover about 10mm then.
    Preston
    Re: Questions
    Quote Originally Posted by GaryS View Post
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    Re: Questions
    like said the largest one at the rear
    Fleet, Hampshire
    Re: Questions
    Ok a couple more questions, this one way valve, i looked a connecting it up near the throttle body and the tread is different? whats the best way to go about it?
    Next
    Ive just looked at the wiring loom and that seams a mission to wire it all up, any tips? does it have to be cut?
    Cant the two boxes of the loom sit the the scuttle bay?
    Thankyou
    Dec 2004
    Aylesbury
    Re: Questions
    Next
    Thankyou
    On my inlet manifold i tapped the tube that normally has the standard volvo servo pipe connected to, then screwed the one way valve into that. If you have look at my B18FT Extra thread (engine pic) you'll see what i mean
    As for wiring its pretty easy mate, it took 3 wires connected to the volvo loom to get the van started. All the joins will be at the pink/red plug on the end, thst where it'll connect to the car. There is a guide on here on which wire goes where, i can't remember off top of my head bu you'll need to know if you got early or late loom
    Yeah the ecus can live in the scuttle area, be worth protecting them though.
    Fleet, Hampshire
    Re: Questions
    Ok cheers Mark. Can i cut up the loom? so its the right length as the loom is super long.
    My loom is from a 480 turbo on a 1990 plate if that helps.
    Cheers.
    Aug 2009
    Newcastle
    Re: Questions
    Regarding the loom everyone runs it anticlockwise from the coil, maf around the front, normally across the top slam panel to icv, alt etc then to the injectors and through a hole in the bulk head, its a pretty good fit tbh.
    Im a fanny and took mine from the alt in between inner and outer drivers wing, cut 2 holes so it came in behind the battery which on my car is on the drivers side then down in behind the dash right round the back of the heater matrix and mounted the 2 ecus nice just behind the fuse box. I then used the spare fuse block holder fitted another block with my 4 fuses and wired up from there to the fuel relay, ignition barrel etc Nice and tidy
    phil
    Fleet, Hampshire
    Re: Questions
    More help needed. Im just working on the loom now, the live feed to the loom does that just go to the live output on the altonator? what goes in the top single plug on the altonator, does one of the original loon wires connet there?
    Also the oil level plug on the sump has 4 wires from it which 2 do i need to connect it to the renault loom?
    Thankyou
    Aug 2009
    Newcastle
    Re: Questions
    Thankyou
    The red wire goes to the alt live, the top single plug uses one wire from the Renault loom think it goes on the right spade, that will give you the light on your dash and I think the plug on the sump black if I remember is oil temp, nothing to connect it to. I think that's all right it's been a while, I'm sure someone will correct me lol
    Fleet, Hampshire
    Re: Questions
    Ok next question
    i took my ht leads off ages ago and now dont know what goes where, help please
    Re: Questions
    I think the dizzy cap or white plastic thing has the plug numbers stamped on it IIRC.
    Non-member sieger's Avatar
    assen city
    Re: Questions
    tomorrow evening i can take a look for you.
    Fleet, Hampshire
    Re: Questions
    thanks people
    Fleet, Hampshire
    Re: Questions
    Hello again
    Is the cooling system self bleeding?
    Can i connect my std temp guage to the engine? if so where?
    Thanks
    assen city
    Re: Questions
    Hello again
    Thanks
    depends how you connect the cooling circuit, i always put pressure on the exp tank.
    you can you your std gauge, it is located just above thermostat. it only sees to much on the gauge.
    Re: Questions
    Use your standard gauge and swap the sensor for the one on the c1j.
    Fleet, Hampshire
    Re: Questions
    Right car is on its wheels!
    now, the starter motor is just spinning and not engaging ?
    also i cannot hear the fuel pump priming ?
    help! its so close to starting i hope
    cheers.
    Fleet, Hampshire
    Re: Questions
    Fuel pump wiring? help
    Fleet, Hampshire
    Re: Questions
    Right, wire help i have,
    Thick grey
    grey + red
    orange
    blue + brown
    green
    what goes where as ive read so many different posts on here and im lost, i have no fuel pumping
    Thanks
    Re: Questions
    Pm for ya fella, something Andy sent me ages ago tells ya all you need to know
    Fleet, Hampshire
    Re: Questions
    White / blue wire? cant see that one?
    Re: Questions
    The pump didn't prime on cranking, does it when you stop.
    Dec 2004
    Aylesbury
    Re: Questions
    Thick grey
    grey + red
    orange
    blue + brown
    green
    Thanks
    Sounds like you got an early loom on your car mate
    From what remember (done one little while ago in Clio)
    -Grey = 12v ignition
    -Grey/Red = fuel pump
    -Orange = cranking 12v
    -Blue/Brown = rev gauge
    Will double check but sure that was it
    Fleet, Hampshire
    Re: Questions
    cheers people, help me
    Thanks
    Fleet, Hampshire
    Re: Questions
    I have fuel pumping! and a relay clicking! but not even trying to fire up
    Re: Questions
    Do you have a spark? When mine didn't fire up it was due to the injector harness and the loom where they met a pin had been pushed in worth a shot.
    Fleet, Hampshire
    Re: Questions
    I will have alook tomorrow cheers. Im off out to the pub now to sit in the garden and have a cold beer or two
    Cheers.
    Fleet, Hampshire
    Re: Questions
    IT started!!!!!!!!!!!!
    but my rad dont get warm but my header tank does it burns my hand
    also if i unplug my idle control valve it runs much better
    Fleet, Hampshire
    Re: Questions
    Ive done mine like Haz said in another post,
    cant find any pics atm, assumin your usin std volvo bits and the gtt header and gtt rad. on the back of the head there's a pipe with 3 outlets.
    largest goes to heater matrix lower port, back out of top into header tank nearest port, out of other side to metal pipe that runs round front of block.
    highest one goes to top port of header tank, self bleeding.
    bottom one goes to lower of turbo ports, out other side and back into metal pipe round block
    But i have no heater matrix so ive gone from the large outlet on the head to my header then the other header pipe to the pipe which runs around the block. Also ive done the outlet of the turbo to the pipe that connects to the rad.
    I only ran the car for a few mins and my header tank was hot! but how ling should i let it run for to give the rad a chance?
    Thanks.
    Fleet, Hampshire
    Re: Questions
    Anyone help me?
    Re: Questions
    Mines basicly the same, but the turbo goes to the outlet in the metal pipe that goes roubd the block by the oil filter. Is your stat New?
    Fleet, Hampshire
    Re: Questions
    My stat aint new, can i chuck it in some boiling water to test it?
  41. #41
    Farnborough
    Re: Questions
    Yep, put it in a pan of hot water and see if it opens. Of course you may also want to use a thermometer to check its opening at the right temperature as well.
  42. #42
    Fleet, Hampshire
    Re: Questions
    I best stick the kettle on then
  43. #43
    Re: Questions
    The herder tank will get hot first as hot water from the head will go there first, the stat should open after about 10mins keep feeling the hose from stat to rad to feel when it starts getting hot. Then leave it and keep an eye on the temp checking the rad is hot at the top (no airlocks) and that the fan cuts in. Have you fitted the temp sensor from the c1j for the gauge? If so it should go to the 11o'c line then the fan cut in. If you're using the Volvo sensor it will be at the slats when the fan should kick in.
  44. #44
    Fleet, Hampshire
    Re: Questions
    What about my idle control valve?
  45. #45
    Re: Questions
    What about it
  46. #46
    Fleet, Hampshire
    Re: Questions
    haha
    it runs better with it unplugged than it does when plugged in ????
  47. #47
    Re: Questions
    Strange, I know when unplugged they idle higher. I don't run one but I wouldn't sudgest it as I will be going back to using one. Maybe your throttle body needs adjusting, but I'm just clutching at straws really does it idle slow when plugged in then?
  48. #48
    Fleet, Hampshire
    Re: Questions
    It just runs smoother when unplugged , idle didnt slow but i will check tomorrow to make sure. How do you adjust the throttle bodie? ive fitted a 2.0 jobbie.
  49. #49
    Re: Questions
    There's a brass screw under a plastic cap, but if that cap is still there chances are its never been adjusted so leave it. The icv itself may be at fault, but I have no idea how you would test it.
  50. #50
    Fleet, Hampshire
    Re: Questions
    Next questions
    Rev counter, ive read it connects to pin 8? on the clocks but which of the 3 plugs is it on the dials?
    Also i think i just boiled my water thermo must be stuck.
    It takes a good few cranks to get it started is that because i anit changed my pump yet?
    Thanks.
