Results 1 to 9 of 9
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Thread Sealant - AN fittings
    Can anyone confirm if you should use a thread sealant on male AN fittings?
    I know the connections seal on the conical faces but I'm talking about the straight adaptors that you would fit into your fuel rail or FPR as below... I know it has an o-ring to seal on but wonder if I should use some thread sealant aswell for good measure?
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Thread Sealant - AN fittings
    Is slap some ptfe tape on just to be doubly sure bud doubt you even need that.
    Dartford
    Don't use ptfe tape, the petrol will eat it away!
    Just use some thread lock, it's petrol resistant
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    It depends on the fitting, the AN bit is the conical end. If it's NPT it should seal, or if it's some BSP or metric fitting then it'll want a copper washer, o-ring or similar. If it's not a taper thread don't use sealant. It might seal for a while but there is no guarantee it'll last Definately no ptfe tape as mentioned
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Yeah its not a taper thread its a straight adaptor, 9/16 UNF, as per the photo, the fitting comes complete with an o-ring to seal off on but I just wondered if people use some sort of threadlock/sealant more to stop it coming loose over time.
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    You could put a dowty washer on it instead of the o ring.
    don't listen to me then
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    That 9/16" is quite common on regulators, rails etc. They usually use an o-ring like pictured but in those cases there is a land around the female thread to accept it. Dowty or copper washer is the other way if the surface around the thread is level.
    Non-member JohnAldridge101's Avatar
    Feb 2010
    on military aplications we use loctite 572. works very well.
    http://www.loctite.co.uk/cps/rde/xch...ID=1000000IXOY
