Right! Still having problemssss!
Car runs perfect, starts perfect, totally reliable over last 15months since buying it!
Had problems with it running lean from day 1!
Got an aem afr fitted reads 14.5 on tick over from cold sticks on this tho even on boost? It drops to 13.6 after a short run! It also goes into red 16/17 sometimes when on boost then goes back over to 14ish as the boost rises!
So I now running it back on the t2 with standard 8psi boost!
I've fitted new:
fuel pressure regulator
Fse racing fuel pump
Fuel filter
Carb (standard jets)
Removed fuel filter in carb
Cleaned fuel filter in tank sender
I've now been told it could be:
Timings out?
Enrichment jet problem?
Major boost leak?
I need a proper
Mechanic ASAP now!!!
Anyone local to Manchester that's free this week or weekend??
Thanks guys
