Results 1 to 10 of 10
    Non-member REBEL GT TURBO's Avatar
    Jan 2011
    annoying water!
    I'm getting water gathering under my bucket seats! cant see where its getting inn?? Is there any areas that usually leak
    Thanks
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: annoying water!
    Sunroof, door seals, matrix, through bulkhead is scuttle drain holes are blocked.
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: annoying water!
    just drill a hole in the floor and forget about it.
    Re: annoying water!
    Or shoot a hole
    Non-member TrixNFlix's Avatar
    Preston
    Re: annoying water!
    My bet is bottom corners of windscreen. It's Deffo not heater matrix Russ as that's new.
    Jan 2011
    Re: annoying water!
    How do I go about fixing that mate? Is it a case of windscreen out reseal it and back in?
    Preston
    Re: annoying water!
    Would of thought so, That screen was supposed to of been put in new a few months before I bought it, don't think it has any chips or cracks in so just needs resealing back in. Or is it worth getting a new one through your insurance for less hassle?
    THE BAT CAVE
    Re: annoying water!
    another possibility of water getting in is from inside the doors,remove door panels and see if the seal is stuck all way around,if not stick it back or if not there tape up the holes with nice neat lines of gaffer tape.
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    Re: annoying water!
    Go to a jet wash with a mate and one of you stay in the car, im guessing you have no carpet if you spotted it under the seats.
    Member Lomo's Avatar
    Wirral
    Re: annoying water!
    Can be prone to rotting under the drivers footwell. Take the carpet back and check the corner around the accelerator pedal.
