Results 1 to 5 of 5
    Non-member 123-gtt's Avatar
    Nov 2011
    Aaaahhhhh
    Have just went 12 round with the car, and lost badly
    iv got a 2/12 inch sidey from the turbo elbow, im trying to get the front section of the exhaust to go on to the down pipe (the one with the spring bolts) how the heck do you do it? iv spat the dummy and come in doors, lol
    Non-member Nick k's Avatar
    Leicester
    Re: Aaaahhhhh
    Have you got the correct bolts? they should be bolted to the turbo elbow with 2 x 13mm nuts on it. This leaves you, ( 0n the other end of the bolts) 2 x long 2" bolts sticking down. You should then be able to mate the exhaust to the turbo down pipe, then slide the clamp bit along then over the 2 long bolts, then springs on and finally 2x washers then 13mm bolts.
    Nov 2011
    Re: Aaaahhhhh
    Quote Originally Posted by Nick k View Post
    Top bit done,it's the long bolts with the springs where the problem is,It all Lined up,it's just getting bolts though the holes and holding everything in place,guess its would be easier with a standard exhaust as its smaller and have a bit more room.
    Do you offer the bolts down over with springs to the bottom,that's the way it was when I took the old one off.
    Re: Aaaahhhhh
    Quote Originally Posted by 123-gtt View Post
    Cable ties are your friend!!!
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    Re: Aaaahhhhh
    I find going from the underneath is easier ?
    I put one pair of wheels on the kerb , and other on the road. I can then just about reach and get them on ..
