Results 1 to 10 of 10
    Jul 2009
    lost
    wheel size can you get 8 j 15`s on a five?
    any one know or tried?
    Re: wheel size can you get 8 j 15`s on a five?
    philr5t is about to try he has just got a set
    Jul 2009
    lost
    wicked ! update me on how it goes any pics etc
    Non-member newbstar*'s Avatar
    canterbury
    t.k done this, think he's in japan though.
    Non-member Hi 5's Avatar
    wakefield
    you can but you would have to put wider arch on the rear
    Non-member philr5t's Avatar
    Dec 2008
    tadworth
    Quote Originally Posted by Hi 5 View Post
    I'm hoping my rim sticks out the rear arch slightly but the tyre should sit still in side the arch depending on how low you want to go will depend if you need to cut the lips off the plastic arches for the tyre to miss should be fine with a stretched tyre going to try and get my Tyres fitted tuesday then I'll whack a picture up to show you all if it fits
    Jul 2009
    lost
    Quote Originally Posted by philr5t View Post
    that souinds mint! get pics up asap
    wakefield
    standard ride height should be ok with stretched tyres but stiff on dampers may be limiting stops
    Dec 2008
    tadworth
    Ok mate cheers did you leave yours at standard right height then when you had your 15-8" on there mate
    wakefield
    no i tried when it was on the floor and could not get them in lol
