Results 1 to 14 of 14
    Dec 2011
    Side exit exhaust
    I am thinking about buying a side exit exhaust for my 5 but other than having to get the bodyshop to delete the the original exit cut out in rear bumper what else would I have to do and is it worth it
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Re: Side exit exhaust
    Nothing else involved in fitting one. An 2.5inch crossover pipe will help you mate the sidey correctly. without one you may need an adaptor to get the thing to seal at the front join
    Classifieds Moderator
    Mar 2004
    wrighy on here cut the sill and welded it/modded the skirt to allow the pipe to sit higher..
    looked tidy
    i however go by the bang, clunk, scrape rule...
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    its a sidey,chop the sill about all you want you still got a silencer where its not ideal to have a silencer,unless you chop that out...tractor 5...
    Dec 2011
    Does the Sidey silencer sit in the original exhaust position then a pipe out has anyone got pics of one fitted
    Non-member gttjames's Avatar
    Cambridge
    it takes the same route as any other 5 exhaust, down the centre, but then where the hanger is near the rear wheel it comes out under the sill (so this can catch on bumps and so can the silencer in the middle of the exhaust)
    burton on trent
    But they are still by far the coolest exhausts for the r5
    THE BAT CAVE
    before it goes on have some 'ramps' welded onto each end of the silencer it will help when your going over stuff.
    Dec 2011
    Bloody he'll they scrape that bad do they
    I crushed the bottom half of the silencer on mine on a speedbump, hasnt really caught since
    Member Woznaldo's Avatar
    Canberra, Australia
    An old skool trick that you rarely see these days but, well worth it.
    THE BAT CAVE
    mines crushed to,and louder due to keys pops now an then,sidey rage!!
    btw once you key pop you wont want any other exhaust...
    Dec 2011
    What's key pop lol
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    WOT , switch off engine and back on again really quickly..
