Results 1 to 6 of 6
    Non-member SCHWARTZ's Avatar
    Wallington south london
    maf settings?
    whats a good starting point to set my maf sensor for 1.5bar boost?
    Re: maf settings?
    Also when i try to measure the resistance through the 2 outer pins on the maf the merter goes from -1 to say 96 then back to -1 then if i do it again it will be a completly different number wtf is going on /what am i doing wrong?
    Non-member WADDIE's Avatar
    Cheshire
    Re: maf settings?
    contact Tim aka REGGIE on here fella bcos he's just set his up with Haz with the ohm meter the other week at scoffs rolling rd day bud! he was using a 32mm bypass hole and was on saab red injectors m8 if that helps?... not sure what ohms he was using but ran a 228hp im on adaptronics now and can't remember for the life of me what i set mine to.
    Cheshire
    Re: maf settings?
    i ment REGGY5GT
    Re: maf settings?
    Cheers matey will do
    Cheshire
    Re: maf settings?
