Results 1 to 14 of 14
    Non-member going_downhill's Avatar
    Sep 2010
    Megane II Rotary switch
    Has anyone much experience in changing these things? Any tips on airbag removal would be good as i dont fancy it going off. Plan is to disconnect the battery and give it a tap through a hole in the back of the steering wheel.
    Only other thing i'm a little unsure of, is if my used rotary switch is centralised or not. I guess it should be as simple as turning it as far as it will go in both directions and finding the central point. I dont wanna f*** it up as it doesn't look like the most rubust thing in the world. Probably why it snapped in the first place.
    Any help appriciated.
    Non-member gtmatt's Avatar
    manchester,sale
    Re: Megane II Rotary switch
    Quote Originally Posted by going_downhill View Post
    Are you talking about the sswitch disc for the power for the steering wheel bag ??
    Sep 2010
    yeah its the cable that connects the drivers airbag. also known as a clock spring or airbag squib.
    its actually the whole unit behind the wheel including the indicator/light stalks and this cable is sealed inside that unit.
    manchester,sale
    The bag has 3 torx screws at the bag and pull of gently ,with batt disconnected ,then there is the little lead that connects to the plastic ring , I bought the whole unit of eBay wiper stalks air bag etc for £15 .
    Are the indicators not cancelling or horn wires worn away which pass by that ring ? That's what happened to me
    Non-member mike r5 gtt's Avatar
    Jul 2009
    Think there should b a hole in the back of your steering wheel which leads to the airbag release clip, slide a flat bladed screwdriver down there and force the clip down towards the footwell and the airbag should unclip,
    No need to disconnect the battery just make sure the ignition is off, and make sure the steering wheel is straight before u take it off , also make sure the new switch hasn't been turned, they normally have a seal/tag/tape etc on them to stop them turning
    Sep 2010
    well i got it sorted after a morning of swearing. snapped a clip on one of the connectors so lets hope it stays put without. also the radio code out the manual doesnt bloody work!
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    They are a nightmare to unclip
    manchester,sale
    Might be a different radio go to Renault with serial number they will generate a new code
    Sep 2010
    is it worth me trying an ebay seller who claims they will email me the code for 99p once i get mine out to reveal the serail number of the stereo? Its an in-dash 6 disc changer so i kinda want to keep it.
    My rotary switch has since snapped again i must have made an epic fail when counting the rotations to make sure it was centralised...
    £155 for a new one thats centralised and ready to bolt on. ouch. . On a plus note the broken connector has stayed put.
    Having dramas with the electric windows now only going down/up in stages and the keyless entry has stopped working.
    will someone just come and torch the thing??
    MOT tomorrow so will see what other damage its going to cause.
    manchester,sale
    Should be free from Renault if u r nice to parts man ,I bought my switch of eBay of a breaker
    Sep 2010
    I'll try my luck with the renault garage tomorrow with the radio code. Did you get one for the megane 1, or 2 off the net? I paid £70 for a used one for the megane 2 thats now as buggered as my original. If the breaker doesnt take it off with the wheels straight its not much use, (i'll just bugger another one up)... Gonna have to get ripped off on a new one. I think on the early megane the squib is seperate but for the 2 its the entire indicator/light stalk assembly, hence the sky high price.
    Oh well. At least the 5 works.
    Jul 2009
    if you start the car without the card in the slot, then switch it off and get out and try locking the car using the drivers handsfree button it sometimes sorts out the handsfree locking
    ref your one touch windows working in stages, put the glass all the way up and then let go of the switch and then hold the switch up again for 5 seconds and your one touch should b reset
    perils of disconnecting your battery
    u have pm about your radio code
    Sep 2005
    Parkgate Cheshire
    Quote Originally Posted by mike r5 gtt View Post
    Sep 2010
    Windows sorted! who would of thought it? I'll have a look at the keyless entry but to be fair i can live without it if need be.
    Thanks for the help buddy. I'll PM you the relevant info regarding the stereo!
