Ok I jokingly put a post about pulling apart a gearbox in the general chat section but now I've got the box apart I'm having trouble finding what went wrong.
First off the symptoms, the box made a loud grinding noise and slowly loss more and more drive till it had no forward drive at all, reverse still worked but nothing forwards, now before anyone says it THE CIRCLIP HAS NOT POPPED OUT, I put the problem down to the diff packing up but all the teeth are intact on the diff.
the only thing i could find were some damaged teeth on the first cog which meshs with the big cog on the diff but its not every tooth and its only the tips that are damaged, could this be the problem?
