Results 1 to 9 of 9
    Non-member 123-gtt's Avatar
    Nov 2011
    rear brake lines
    Hi all,is anyone on the site making up rear brake lines as mine have seen better days?
    Non-member car.crash's Avatar
    Aug 2006
    Re: rear brake lines
    rubber ones over rear beam or the green steel ones?
    Classifieds Moderator
    Mar 2004
    Either way be careful, bleed nipple snap 99.9% of the time so you might want to replace the lines and end up with calipers too.
    If its the flexi's it's easy, if it's the lines it's not that hard and I have the tools to make them up. We'll talk when I see it
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    you can buy replacement copper kits on e-bay allready made up.
    Non-member REGGY5GT's Avatar
    Nov 2009
    shropshire
    Nov 2011
    good man ashy,are we having a pint over xmas??
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Quote Originally Posted by 123-gtt View Post
    Hope so!
    Non-member CHUNK The Goonies's Avatar
    Bobbys job. Done all my brake lines . You can buy the brake line from local motor factor 10 mtrs for around a tenner. Get a flare kit . Cheap for 15-20 quid and some new nipples, and adapters . Prob 4-5 quid in total.30-40 quid and a few hours under the car job done . Cross fingers that your nipples come out or you talking 80 quid a caliper. . I took mine to a chap who welded on a washer to the broken nipples and after a few attempts twisting the bent up washer out they came. I put stainless ones back in with a blob of copper slip and bought some nipple covers off foe bay for a couple quid.
    Mr ash will lend you his easy bleed kit.
