Results 1 to 9 of 9
    Non-member tiff_lee's Avatar
    Glasgow/Lincs
    Welding patches
    Just a quick one for the welding experts/gurus, I plan on welding some patches to my five and the welding itself isn't the problem.
    What i'm curious about is whether or not it is possible to coat the area being patched over to prevent it rusting underneath. Basically would the overlapping area of the patch be at risk of rusting underneath(between the two layers of metal)?
    Not sure if I have made my point clear enough, I know what i'm trying to say hopefully you understand me
    Non-member car.crash's Avatar
    Aug 2006
    Re: Welding patches
    you would need to treat the new are after the welding has been done otherwise the weld will burn the paint off and the weld would be crappy. i take it your on about sills?
    Glasgow/Lincs
    Re: Welding patches
    Yes mate, I know to treat it afterwards just didnt know if the area being patched over should be treated in anyway (after being cleaned to bare metal) prior to being patched.
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Re: Welding patches
    If you can avoid patching over and try and cut out the rot, as the rot will still there underneath.
    Dublin/Ireland
    Re: Welding patches
    u can weld through zinc rich primer!!
    Glasgow/Lincs
    Re: Welding patches
    I was planning on removing all rost and rot bringing it back to bare metal, perhaps even cutting out the worst of it prior to patching.
    Excellent suggestion Michael! zinc rich primer I think is just the thing I was looking for, now I can prime the area to be covered by the patch so no worries of any exposed metal underneath.
    Thanks for all the tips guys.
    Non-member Philclubman's Avatar
    Rochdale, Manchester
    Re: Welding patches
    Best way is to cut out any rust and weld in a fresh peice of steel, its not really any more dificult, if you plate over the rust, it will rust through the new patch soon enough.
    If you cant cut parts out, grind them back as best you can and use some rust inhibitor then plate over it
    cheshire
    Re: Welding patches
    What about the area behind?? That is ware most the damage orrurs ie the water seeps into inner sill and collects runs into outer etc etc.
    Kilbirnie
    Re: Welding patches
    You can buy a spray on zinc primer thats weld through from a company called Frost, i've used it loads its a blue liquid that once dried can be welded through easily and the fumes are ok. Then treat anything welded and bare metal with a product called por15, it forms a rubber like coating. iv'e painted panels 6 years ago with it and not painted them.............still no rust!
