Results 1 to 5 of 5
    hasselt-belgium
    clio turbo low boost but how much?
    Yesterday i bought a clio turbo. Its an f7p with a bbtuning turbo kit(?) the pistons were machined for lowered compression. The guy told me he bought the kit like this from bb. Maximum boost is now 7psi but this doesn't make me verry happy. I was wondering how much boost i could run. This would be the low boost conversion.
    Non-member 5teve L's Avatar
    RH12
    Re: clio turbo low boost but how much?
    Quote Originally Posted by sega View Post
    Depends how much was taken off the pistons.
    & you will need a high boost chip, a remap or aftermarket management to get any more than 8 or 9 si out of it. You will also need to listen for det & read AFR's if going outside the boundries set up on your chip. Oh & it prob has a T25 on & not a T28 turbo...
    hasselt-belgium
    Quote Originally Posted by 5teve L View Post
    I will have to hear how much was taken of and what chip is inside. Afr is maby possible to read from the xrd that is inside?
    How could i read for det?
    The turbo is T28.
    Just saw it has a cat (original) under the car. would it make much difference when removing it.
    hasselt-belgium
    Opened the ecu just now and it said
    chip 0,8 bar (11,6psi)
    pistons machined -1mm
    Sounds like a low boost chip
    Going by Steve's 1.9mm skim which roughly took compression down to 8.5:1 yours are fairly high comp.
