Results 1 to 4 of 4
    Non-member boysie's Avatar
    Sep 2009
    huddersfield
    ecu plug id, cos im a muppet!
    i took ecu's off the loom while doing some work, and then forgot which goes were, thought they would only fit there own, but no, both plugs are the same
    so i noticed one has a few different pins missing to the other so wondered if someone with a b18ft loom could id which plug is for which box.......please!
    see pic below
    thanks
    Member clee's Avatar
    Derbyshire
    Re: ecu plug id, cos im a muppet!
    Have you tried fitting them ? One has a slot in the ' latch ' area ,top right , so perhaps that matters ??
    Sep 2009
    huddersfield
    no have tried with battery disconnected and they both fit each other
    Sep 2009
    huddersfield
    pics disappeared
    never mind, i worked it out in end, ecu plug was slightly different and had a clip bit in middle of plug,
    should of gone to specsavers!
