Page 2 of 2 FirstFirst 12
Results 51 to 90 of 90
  1. #51
    Non-member markey b's Avatar
    Bury St Edmunds
    Re: Renault 11 with supercharged F7P project
    mot booked for saturday, then off to tax it after work
  2. #52
    Honorary Member Bruce - BHPerformance's Avatar
    Warminster, Wilts
    Good luck with the MOT.
  3. #53
    Fingers crossed all goes well matey
  4. #54
    Bury St Edmunds
    mot should sail through
  5. #55
    Non-member TNT ANDY's Avatar
    Good luck fella!
  6. #56
    Bury St Edmunds
    got more bits done last night...
    mopped the whole car so its actually shiny again, and topped it off with some wax
    oil and filter change
    cold start injector wired into boost switch
    fitted thermostat and made sure it runs at correct temp
    all set to bring it home this eve on trade plates
  7. #57
    I wonder how well the cold starter injector will work when on boost you plumbed in and AFR gauge yet? hope your monitoring for det / knock aswell. I know you have lowered comp but standard ECU and standard injector's
  8. #58
    Bury St Edmunds
    i've no idea, but i've got snetterton next friday on a standard ECU and 7psi so should add some extra safety, switch opens the injector so should just flow 4bar fuel pressure through it on boost... i'll report back lol
    no AFR yet as its hardwired into the orange 5, will borrow an LM-1 on sat just to check and make sure its roughly right, but can't drive it legally until sat afternoon after the MOT and after i've taxed it
  9. #59
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Cold start injector
    Have you lowered compression at least ??
  10. #60
    Bury St Edmunds
    couple more pics of it during/after clean
  11. #61
    Bury St Edmunds
    Cold start injector
    yes, 0.5mm off piston face and a dish 1mm deep, and 4bar fuel pressure
  12. #62
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Ah good, I think you should get away with standard timing
    I don't know if the cold start will provide enough fuel for that 40-50% power increase.
    A better budget option would be an MF2 and a pair of injectors a little upstream of the throttle. The cold start isn't going to atomise or supply equal delivery as well as additional injectors would.
  13. #63
    Bury St Edmunds
    the cold start is just a belt and braces until i get it mapped, then i'll get bigger injectors in and the ECU flashed to suit a s/c, and go from there. its only running 7psi so i'm not expecting a rocket
  14. #64
    Bury St Edmunds
    little update, it had to fail mot on sat, but failed on OSR sill corrosion and OSF wheel bearing... not bad for an old shed.
    bro has been busy welding, and last night i put on the GTT front struts and hubs complete with clio 16v brakes, and then lowered rear beam
    pulled the NS bar out with a spanner and a bolt, unbelivable considering its age!
  15. #65
    Jan 2000
    Awesome!
    Especially the Krypton Factor sticker!
  16. #66
    Nice sleeper get that ecu mapped properly though and enjoy reliable power, the cold start injector is too pikey
  17. #67
    Nice one ButterBollox - really glad you've done this to the ol' girl. Very nicely done as usual.
  18. #68
    Mar 2011
    Mega project! awesome for 3 n half weeks
  19. #69
    Bury St Edmunds
    thank u
    its still in the workshop having a bit of welding, turns out that when it was repaired before they liked filler! all good in the hood tho, my bro is on the case and he's making repair panels from sheet metal
    money is the only thing holding it up, after another bottom end as my pikey build is knocking under load, tbh its laster longer than i thought
  20. #70
    Non-member Rare.'s Avatar
    Oct 2011
    this is cool
  21. #71
    Bury St Edmunds
    still not driven it properly yet due to lack of tax, and may have to sell it due to lack of funds
  22. #72
    Non-member Schakal's Avatar
    Barry
    Did you manage to get this to run properly at all mate ?
    What type of supercharger have you used ?
  23. #73
    Bury St Edmunds
    Quote Originally Posted by Schakal View Post
    havn't driven it yet fella still needs tax, its all mot'd and legal apart from that, just need to pop it down the road to make sure it boosts ok now
    supercharger is eaton M62 i believe, of a merc, from this months PPC cover car no less
  24. #74
    Bury St Edmunds
    little update...
    bottom end was lunched so decided to swap it out for a new one, so engine out again
    new bottom end in and built back up, just needs a few bits of plumbing in finished
    then by complete luck, the worlds most complicated car exchange was discovered... so in 3 weeks the 11 will be going to a new home
    basically, swapping the 11 for this....
    which i have swapped for this....
    which i've already swapped for this....
    complicated, but so far so good... shame the 11 is going but i've still got the orange 5 for kicks, diesel for daily and now a 'ped too
  25. #75
    Jul 2009
    lost
    that blue five is gorgeous!
  26. #76
    felixstowe
    blue 5 is nice where has that came from?
    nice bike though saying that the clio looks nice too lol
  27. #77
    Nov 2010
    Thats mine
  28. #78
    Jul 2009
    lost
    that five was really smart mate why did ya get rid of it? and who owns it now?
  29. #79
    Dec 2004
    Aylesbury
    Quote Originally Posted by r5_scotty View Post
    He's still owns it mate as i've got some bits for it still, need to go give them to him soon so its ready for him
  30. #80
    Nov 2010
    Yeah as Markey says I still own it mate, I lost my license for 12 months and gunna have driving without insurance and TWOC on it when I get it back No one will insure me on a GTT with that record, being only 20 If all goes ahead me and Mark B will be doing a straight swap BUT the 11 is still insurance group 6 so am abit stuck really
  31. #81
    Bury St Edmunds
    Quote Originally Posted by BabybluGTT View Post
    insurance will always be a killer with TWOC, group 6 is alot better than 14 and turbo in the name tho lol
    soon as markey has worked his magic lemme know 11 is back together now
  32. #82
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    you stole a car or is there a bigger story..... might want to clarify that being in a club full of car lovers.....
  33. #83
    Bury St Edmunds
    i'm pretty sure its part of the story, i'm sure he will explain if he wants too
  34. #84
    Nov 2010
    Haha good shout Tony, my mrs at the time told me to take her car. She wasnt best pleased when I phoned her and told her i'd written it off though! So much so that she smashed my 5 up with a hammer (drivers window and windscreen & ripped the battery out ) I said I took it without her consent so she didnt get into any trouble Needless to say shes not my mrs anymore.
  35. #85
    Sep 2005
    Parkgate Cheshire
    Damn sorry to hear bout the 5 she managed to rip the battery out??????????????
  36. #86
    Ivybridge
    Mark, i take it you are using the standard ECU? Who were you going to get to map it up?
  37. #87
    Bury St Edmunds
    james5 says there is someone on cliovalver that can reflash them for £150
  38. #88
    Nov 2010
    Well someone there managed to go through the terminal clips, god knows how lol cut straight through them both Thanks mate, it was a moment of stupidity, finally got my dream motor and now Im gunna loose it
    Sorry for the hijack Mark
  39. #89
    Ivybridge
    Yeah ive been in touch and he seems very genuine. He has a website now too linked from the clio williams forum.
  40. #90
    Sep 2005
    Parkgate Cheshire
    On the plus side youll get a pretty awesome 11
    Sorry also for the hijack Mark.
