Results 1 to 4 of 4
    Anyone out there fit (or fitted) windscreens for a living!
    Looking for some advice….
    I’ve removed the (damaged) bonded front screen from my 5 GTt. Did it my self, using the correct tools, wanted time to check & repair any hidden rust, fortunately there’s very little corrosion.
    I’m intending to have a profession fitter install the new one….however how much of the bonding adhesive do I need to remove now the screens out?
    I’ve scraped all the old black bonding mastic/adhesive flush with the aperture as far as possible leaving a flat clean surface.
    There’s still some traces left, do I need to remove all 100% of it? If so is there a solvent which would do the trick, tried petrol and thinners without much success…it tough stuff.
    Thanks
    Re: Anyone out there fit (or fitted) windscreens for a living!
    I removed all the sealant but you don't have to. If you follow the manufacturer instuctions it says
    leave a 1mm smooth layer of the old stuff and then clag the new stuff on that.
    have a look at
    http://www.sika.com.ph/sikaflex255extra-2.pdf
    Thanks,
    Looks like I gave myself extra.. work
    burton on trent
    important thing is , if you have scratched that paint etc get some fresh paint on it.. r5s are known for rusty windscreen panels, dont help it as you wont get a fresh panel in a few years to come.. prevention is the key.
