Help about new manifold
Hi guys i can't fit my new turbo (on my b18ft) so I need to make new manifold. Could somebody give me some ideas what manifold to make and what size the pipes to be ?
Cheers
Joseph
Re: Help about new manifold
Why not just change the rear housing on the turbo, prob work out cheaper to do it that way if your happy with the original manifold
I don't think the T2 will fit. But could try
why dosnt the turbo fit? is it a different flange? If youre using a standard manifold get a 200sx s14 t28 and be done with it
Trader
Nocturnal Developments
what turbo? manifold will the the hardest and most expensive item to make.
various manifold designs depending what your wanting, equal length for top end power. really long and each other shorter by 25% to get a subaru type burble etc etc. pipe size the same as valves
The turbo is td04L from impreza
I think to make the same manifold as Markey Mark BD
at the moment i'm just getting ideas what manifold to do so if you guys can help me with this it will be very nice
