Results 1 to 6 of 6
    Non-member ioshi_s_golf's Avatar
    Oct 2010
    Manchester/ Bulgaria
    Help about new manifold
    Hi guys i can't fit my new turbo (on my b18ft) so I need to make new manifold. Could somebody give me some ideas what manifold to make and what size the pipes to be ?
    Cheers
    Joseph
    Dec 2004
    Aylesbury
    Re: Help about new manifold
    Why not just change the rear housing on the turbo, prob work out cheaper to do it that way if your happy with the original manifold
    Oct 2010
    I don't think the T2 will fit. But could try
    Non-member SCHWARTZ's Avatar
    Wallington south london
    why dosnt the turbo fit? is it a different flange? If youre using a standard manifold get a 200sx s14 t28 and be done with it
    Trader
    Nocturnal Developments
    Haz's Avatar
    what turbo? manifold will the the hardest and most expensive item to make.
    various manifold designs depending what your wanting, equal length for top end power. really long and each other shorter by 25% to get a subaru type burble etc etc. pipe size the same as valves
    Oct 2010
    The turbo is td04L from impreza
    I think to make the same manifold as Markey Mark BD
    at the moment i'm just getting ideas what manifold to do so if you guys can help me with this it will be very nice
