Results 1 to 3 of 3
    Jan 2010
    AFR Readings
    Hello!
    Trying to get my 5 running right so connected up an afr but not sure if the carb needs a bit more work
    Got afr readings of idle 13.5 wot 11.7 crusing 10.5-11 is this a bit rich or about right for around 18psi?
    drilled out second stage 1.2 standard air corrector and 1.3 main
    Cheeeeers!
    Dec 2004
    Aylesbury
    Re: AFR Readings
    Cruising is alittle rich, rest looks ok
    Are those jets the only ones you changed? I would suggest going back to a 1.2 main and poss going slightly smaller on the ac jet
    Jan 2010
    Re: AFR Readings
    Yeah there the only jets i have fiddled with, thanks for the info i will swap em over tomorrow morn and take for a test run
    Cheers
