Results 1 to 6 of 6
    Non-member adscan's Avatar
    Apr 2011
    Wont start..
    Just gone to start the 5 and it fired like normal. When i pressed the accelerator pedal it just died. now i cant get it started at all. Battery is okay and not had any previous trouble starting.
    any ideas?
    Non-member tiff_lee's Avatar
    Glasgow/Lincs
    Re: Wont start..
    Sounds daft but have you got fuel in it, or more specifically is it getting to the carb.
    Apr 2011
    Re: Wont start..
    yes loads of fuel in tank. could it be the fuel pump?
    Non-member going_downhill's Avatar
    Sep 2010
    Re: Wont start..
    Mine had this problem the other day, get someone underneath whilst you turn it over to see if the fuel pump is alive. Other than that check for fuel at the carb.
    Sep 2010
    Re: Wont start..
    You may aswell just look at this thread and follow the advice i got on there
    https://www.rtoc.org/boards/showthread.php?t=22159
    Apr 2011
    Re: Wont start..
    just had a search...there was no fuel getting to the carb.
    i have swapped over the fuel pump relay and all seems well.
    i am going to change the fuel pump as well as it looks a bit crappy.
