Results 1 to 1 of 1
    Jan 2010
    Rolling road results
    Hi all,
    Just had my car on the rollers to check power. Making 180 hp at one bar boost,
    any advice on the graph print out would be much appreciated as don't really know what I'm looking at!??? Want to get it to around 200, trying to get fueling sorted
    (dotted line is a run with 1.5 main jet, 27mm venturi, 0.9 air corrector, standard other jets. Solid lines is a run with 1.4 main jet, 27mm venturi, 0.9 air corrector and 2nd stage drilled to 1.2mm)
    The rolling road guy couldn't advise
    Heeeeelp
