Results 1 to 10 of 10
    May 2003
    Haslemere, Surrey
    Innovate Motorsport Auxbox (LMA-3)
    Has anyone bought a Innovate Motorsport Auxbox to complement the LC1 wideband sensor?
    Looking at buying it to record boost pressure and revs.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Innovate Motorsport Auxbox (LMA-3)
    Quote Originally Posted by GordonB View Post
    I've used one but didn't ever buy one. they're old hat now. they're handy if you want to log dwell angles of ignition or injectors and other random things but if your only interested in boost, RPM and AFR then get yourself a new LM-2, much more modern and logs direct to an SD card. You may need an external map sensor, cheap enough on ebay.
    there's a innovate DL-32 also, that looks nice, too expensive for me. It'll log everything you can imagine, built in accelerometers, map sensor, it'll log ignition timing and injector dwell vs. RPM so you can effectivly pinch a 3d map from any car you like.. maybe santa will bring me one.
    May 2003
    Haslemere, Surrey
    mmm... looks decent enough
    cheers
    Guernsey, UK
    I am pretty sure the LMA-3 has a built in accelerometer as well? Also you can record ignition map on the LMA-3 by using a combination of your TDC sensor signal and an inductance clamp on a spark lead. Theres quite a bit of documentation on the net about it. However I haven't done this myself so I'm not sure how easy everything is to install on the 5. I'm hoping to save up for one of these at Christmas so I'll let you know how it goes. If you've already got the LC-1 I wouldn't personally go for the LM-2 as you're paying quite a lot for the wideband AFR functionality which you already have.
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    I have a couple for sale if anyone's interested?
    [/shameless plug]
    May 2003
    Haslemere, Surrey
    [/shameless plug]
    A LM-2 or a LMA-3?
    May 1996
    Pie & mash shop
    Auxbox/LMA-3
    Guernsey, UK
    I'd be interested in one.
    Non-member MR TURBO's Avatar
    bristol
    [/shameless plug]
    How much u wanting???
    May 1996
    Pie & mash shop
    Quote Originally Posted by MR TURBO View Post
    You have PM.
