Results 1 to 19 of 19
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    t28 onto b18ft
    I have been having a look at the two turbos today t2 and sx t28 side by side, it looks pretty straight forward. I have rotated the turbo to match the t2, i read somewhere you just swap all the water pipes and oil outlets over with the standard t2 ones.
    What else needs done, i know i need to make a down pipe what about the side that run to the intercooler it has a triangular end?
    I read gary had problems with the oil feed pipe.
    My actuator has 2 outlets, how does this pipe up?
    I also need an elbow if anyone has one
    Re: t28 onto b18ft
    Phil ignore the rear actuator port and let that just be to air, plumb up the pipes as you have on the orginal volvo T2
    Non-member 5teve L's Avatar
    RH12
    Re: t28 onto b18ft
    Looks like a T25 off the S13 from the piccies, could be wrong though. Does the front of the comp housing unbolt as well as the outlet to intercooler ?
    Non-member boostjunky's Avatar
    Nov 2008
    London
    Re: t28 onto b18ft
    You're going to need to get an adaptor for the compressor oulet - i.e. http://cgi.ebay.co.uk/Garrett-3-Bolt...item588c7e5586
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: t28 onto b18ft
    phill the only prob i had was with the oil feed but ben at hose solutions can supply you with an adaptor to fit the 200sx t28. you will need one of these.
    http://cgi.ebay.co.uk/Garrett-3-Bolt...#ht_1789wt_905
    and poss one of these
    http://cgi.ebay.co.uk/3-T28-TURBOCHA...ht_2498wt_1026
    the r5 t2 elbow will fit with a bit of bodgery but if youre getting a dp made up then i guess youll get one going straight to the turbo. good luck bud
    Re: t28 onto b18ft
    Just seen the pic's that is one weird bodged up actuator setup, personally I would try and use the actuator of the original volvo turbo than that thing.
    As Steve says any pics of the compressor housing front?
    Re: t28 onto b18ft
    dose look a bit nutty but the standard actuator isnt really up to much. might be worth looking for another one matey
    Aug 2009
    Newcastle
    Re: t28 onto b18ft
    Ok guys i will get some more pictures up, im sure its the 200sx t28 with the smaller back on it, it has the same numbers as andys was.
    Do i have to buy that triangular adapter from the us or anyone sell in the uk?
    So gary instead of buying the elbow for the turbo i could just get it all made up with the down pipe when the time comes.
    Any idea how much i should pay for a standard elbow should one pop up?
    Aug 2009
    Newcastle
    Re: t28 onto b18ft
    more pictures
    Re: t28 onto b18ft
    Yes you will need a triangle outlet adaptor. They do come up on the bay from the uk only works out a little cheaper but saves on poss customs charges. The r5s elbows arnt a very good fit so I wouldnt bother buying one and going straight for a complete dp and elbow they do come up on the bay for 20. Big jim can make dp I have tried getting a price but havnt been able to get through for last few days. Have you tried looking at the 200sx elbows on the bay around £50 they can be bolted up to a custom dp.
    Aug 2009
    Newcastle
    Re: t28 onto b18ft
    Thanks gary, is it definnatly at t28 i have from the pics?
    phil
    Re: t28 onto b18ft
    Quote Originally Posted by philg View Post
    phil
    Phil, that compressor housing looks like a T25 to me, the 200sx T28 has something like an a/r 60 trim
    http://cgi.ebay.co.uk/NISSAN-200SX-S...item4cf6b192d4
    RH12
    Re: t28 onto b18ft
    I'm not sure what it is now as it deffo has the .64 exhaust but the front looks like a T25, I did hear that the s13 ran a .64 or the bluebird on some of them.
    Should do what you need it to though Phil but I don't think it's as big as an S14 unit, prob runs different trim wheels.
    Re: t28 onto b18ft
    Steve think your spot on with this turbo being of the earlier S13 that ran the T25 with bigger rear's. As Steve says will still be a good upgrade to what you have
    Aug 2009
    Newcastle
    Re: t28 onto b18ft
    so does that mean power would be down compared to a full t28 and how laggy would it be, does it have a large or small rear guys?
    phil
    RH12
    Re: t28 onto b18ft
    phil
    No idea TBH, best off asking the likes of Adam L
    Re: t28 onto b18ft
    I dont know if it means anything but my and I think steves turbo needed an inlet adaptor as in the link. Even if it is a t25 phill it will most prob be slightly less laggy and defo still be a great improvement over the standard t2
    Aug 2009
    Newcastle
    Re: t28 onto b18ft
    will it get me the magic number though?
    Re: t28 onto b18ft
    Don't see why not if a t25 can do that on a C1J should be easier to do it on the B18ft, the only downside to bodging these turbo's on is the lack of a decent 360 bearing
