Results 1 to 3 of 3
    Aug 2009
    Oxfordshire
    How Much Paint?
    Are there any painters on the forum??
    I'm just about ready to order paint to spray the 5, and I cant decide on how much paint to order. being pearl white, i need a ground, then pearl, followed by clear.
    I dont think i'll need as much as pearl, so i was thinking 4 litres ground, 3 litres pearl. Sound reasonable? Both are mixed 60/40 with thinners.
    stevenage
    Re: How Much Paint?
    That does sounds about right. Obviously depends on how much you are spraying. i.e engine bay, boot or just a blow over.
    Being quite small 3 ltrs of paint done my exterior and parts plus bay nicely.
    Rob
    Non-member kiwicolour's Avatar
    Mar 2011
    Re: How Much Paint?
    your in luck! im a painter and ive only just painted m pearl white phase 1,
    i used 3 litres of ground coat mixed 2:1 (2 parts paint 1 part thinners) (still got a bit left)
    then i used 2 litres of pearl - same 2:1. and got a bit left.
    i applied 4 coats of ground. and 7 coats of pearl.
    dunno how much clear i used as i buy that in bulk, but 5 litres would paint 2 cars this size
    i went for ICI paint as its a better paint, wasnt cheap tho! nearly 300 quid all in
    hope that helps!
