Results 1 to 7 of 7
    norwich
    turbo f7p cams
    who's running standard cams in there f7p /f7r
    stuck a set of na piper 270's in, and now wished i never bothered although where cheap
    how does the standard cams come in on the turbo lump , and is it worth trying the f7r cams out of a williams or megane, or possibly the f4 if they would fit /work , have also spoken to catcams,who do a set of turbo cams, but there a lot of money and not sure if there going to really give me worth while gains over the standard items £ vs bhp if that makes sense.
    any views /thoughts/ ideas welcome,
    http://www.pipercams.co.uk/pipercams...=19&engine=112
    ref the piper cams n/a specs
    couldnt find anything on the catcam turbo profile
    Re: turbo f7p cams
    Got standard cams in my car, works fine for the conversion and just didn't seem worth the cost to what little improvement it may gain from it. As the car could produce more power than I really wanted to run anyway so not like with Scoff who will be trying to get as much from his engine as possible.
    norwich
    Re: turbo f7p cams
    what is the power band like ?
    where does it come in ? turbo size will play apart , im guessing your running a gt28 rs or a turbo of that size?
    Re: turbo f7p cams
    Have to find the rolling road sheet for when it was running the 12psi after a lot more setting up, this was only the initial runs just to get the car running around, this was with a blown turbo but was a T28
    https://www.rtoc.org/boards/picture.p...pictureid=6658
    from what I remember power band was really around the 3k up to 6k where torque was at its higest point, pretty much flattened off up there think it was around the 239lb/ft mark
    norwich
    Re: turbo f7p cams
    cheers for the input there bigfoot ,
    how far have you pushed the boost on your 5, and what bhp/ftlb what should i be expecting at around 25 psi
    Re: turbo f7p cams
    No more tread left on the tyres
    The last rolling road was at 12psi and that was 233bhp and 239lb/ft cant remember what revs they are at though. Got it then holding at 1bar on a road run sorting out the electronic boost controller and boost came on sooner as well which was great, and that is a handful on front wheel drive
    norwich
    Re: turbo f7p cams
    love it
    cant get enough of the booosstt
