Results 1 to 24 of 24
    Member clee's Avatar
    Derbyshire
    5GTT New carbs
    Trying to gauge interest in these for another RTOC group buy .
    http://www.fastroadcars.co.uk/shop/i...&productId=215
    I have negotiated a price around the £175 mark ,maybe a bit less .
    Names please
    Non-member Nayls's Avatar
    Weymouth
    Re: 5GTT New carbs
    im intrested
    1 Nayls
    Non-member BriC's Avatar
    Dec 2005
    Re: 5GTT New carbs
    Definitely
    1 Nayls
    2 BriC
    Aug 2004
    Re: 5GTT New carbs
    1 Nayls
    2 BriC
    3 penfold
    Re: 5GTT New carbs
    1 Nayls
    2 BriC
    3 penfold
    4 Brigsy
    Re: 5GTT New carbs
    More good stuff
    Looks like it needs a couple of little mods to fit the GTT though Clee. Is everyone here aware of what's required and capable of making the changes?
    Also, it says 'the venturi is 24mm not 25mm'. What is the standard size on the GTT and is it going to make any difference?
    Derbyshire
    Re: 5GTT New carbs
    Anthony at Fastroad has assembled a 5 version but yes it does need some tweaking ,not that much though .
    Again , as with the manifolds I can get one sent to someone competent to test fit and function ?
    Aug 2009
    Oxfordshire
    Re: 5GTT New carbs
    1 Nayls
    2 BriC
    3 penfold
    4 Brigsy
    5 Elmof1
    Non-member Logg's Avatar
    Re: 5GTT New carbs
    Quote Originally Posted by clee View Post
    Has he run one on a c1j?
    I've tried running a 18 turbo carb. It was mega rich on boost no mater what the jetting the only thing I didn't change was the smaller sized venturi though.
    Derbyshire
    Re: 5GTT New carbs
    That I don't know .
    I've asked The Wizard to advise .Venturi change is not straightforward he says ...awaiting further pearls of wisdom
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Re: 5GTT New carbs
    I think you have to fit some of your old secondhand parts into the new carb the last time I looked at these.
    Non-member scott 5gtt's Avatar
    May 2010
    stockton-on-tees
    Re: 5GTT New carbs
    1 Nayls
    2 BriC
    3 penfold
    4 Brigsy
    5 Elmof1
    6 scott 5gtt
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Re: 5GTT New carbs
    what 2nd hand parts would need to be fitted.?
    Dec 2005
    Re: 5GTT New carbs
    Any updates?
    Derbyshire
    Re: 5GTT New carbs
    nope ....
    Will get one shipped to The Wizard who will then advise exactly what is required to convert for 5 gtt .
    Classifieds Moderator
    Mar 2004
    Re: 5GTT New carbs
    interested but waiting for the wizards info.. what parts need swapping, and how easy etc..
    Non-member Jörg's Avatar
    Apr 2011
    Germany
    Re: 5GTT New carbs
    when possible i want also one , the carbs are new or new rebuilding
    you can send to germany ?
    TONBRIDGE
    Re: 5GTT New carbs
    Same goes for me.
    Re: 5GTT New carbs
    They only have 4 in stock?
    Derbyshire
    Re: 5GTT New carbs
    ....The Wizard has inspected and compared to the GTT carb.
    Looks like there is way too much work involved to make a good job of it .Pretty much all of it is different or a bugger to alter .
    Trader
    Jan 2001
    Morden
    Re: 5GTT New carbs
    Derbyshire
    Re: 5GTT New carbs
    Is that an 'I told you so ' wink Mike
    Wizards findings below .If anyone still fancies trying it or have other opinions then shout up
    ok i got the carb today and took various bits of it.
    i didnt go measuring all the jets as they can be replaced.
    however....this is what i found.
    1)
    this clearly shows that the casting on top piece of the new carb does not have the pedestals required to screw the studs into that hold the carb top on!
    it also shows that the bracket that holds the choke cable is different, as is the throttle cable mount and also the choke plate itself doesnt have the air hole in it.
    2)
    this shows that the enrichment circuit is also totally different and that there is a vacuum port blocked off on the new carb. the new carb actually has a vac port on the opposite side of the carb, but the feed to it is from under the throttle plate, whereas the standard gtt one actually comes from above the throttle plate.
    i'd have said none of the enrichment block is usable....see the next pic...
    i removed the cover of the enrichment circuit and its totally different inside to a normal gtt unit.
    3) the venturi is 24mm. so somehow you have to extract your old one. extract the new one, and swap them over.... and get it slotted in the right way.
    4)
    the accelerator pump feed jet is blocked. - you have to swap that too!
    5) i also noticed a different hole size in the enrichment circuit.
    so overall, it looks as though the only bit that you'd not have to touch is the throttle plate and carb base section.
    you can't fit a gtt carb top as it stands, and the venturi will be a bit of a stinker to change.
    Trader
    Jan 2001
    Morden
    Re: 5GTT New carbs
    Hi Lee, no not at all but I had been told about these a while ago. Just nice to know that it was not a waste of time.
    Thanks
    Mike
    Dec 2005
    Re: 5GTT New carbs
    Cheers for the info
