Results 1 to 11 of 11
    Non-member 5teve L's Avatar
    RH12
    MOT & wheels
    Booked the wifes 5 in for MOT & i know the front rubs on full lock which is a fail
    Can i put 2 different rims on the front as long as the tyres are good or will they not do it like that ??
    Non-member Sy5GTT's Avatar
    Mar 2006
    Deepest Wilts
    Re: MOT & wheels
    I think it's ok as long as the 2 tyres/wheels are the same size on the same axle. My old 5 use to rub and never failed but that was 10 years ago.
    May 2003
    Haslemere, Surrey
    Re: MOT & wheels
    Quote Originally Posted by Sy5GTT View Post
    Your right.
    i put my 5 in last year with 16"s on the front an 15's one the back. Not a problem
    Non-member Nayls's Avatar
    Weymouth
    Re: MOT & wheels
    They will accept it like that but they will probably make a note of it for themselves incase anything comes of it.
    something similar happened at my local mot station,the tester thought it was strange so took a pic & made a note,sure enough a month down the line,the ministry arrived asking why they'd passed a car with bold tyres! (the lad switched them just for the mot)
    v lucky as they were going to shut them down for a while & send him on some course.
    Non-member Schakal's Avatar
    Barry
    Re: MOT & wheels
    yupp its ok as long as you got same size wheels and tyres on each axle .
    they will put it on the advisories though
    Re: MOT & wheels
    If thats the case Steve you can borrow a couple of my 15" OZ's matey for the MOT if you needed all 4 maybe a struggle as I have puncture on 1 which needs repairing as you inflate it and it pretty much goes down as soon as inflated.
    Non-member GTphil's Avatar
    Re: MOT & wheels
    i had 16s on my five a few years ago and they didnt rub at all? they were 7inch wide not sure on the offset tho.
    anyway i think the reason they didnt rub was because i had spacers on, i know spacers arnt an ideal thing to have on all the time but why not just try some spacers and if it make the wheels clear the arches then just wack em on for the mot.
    RH12
    Re: MOT & wheels
    She has 17's & they rub a bit on lock, can't be arsed with spacers
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: MOT & wheels
    bearing in mind that when its tested there
    is no load on the tyres so it dosent sqiush
    them,you maybe ok,depends how bad they
    are rubbing really.
    RH12
    Re: MOT & wheels
    Failed on a leaky rear shock & a couple of patches of rust, no biggy
    Bedfordshire
    Re: MOT & wheels
    Mine passed with rubbing wheels !!! I think it's only because when cars jacked up they drop bellow the point where they rub oh and you could have a mixture of wheels as long as matey before said that there same size on each axle !!
