Page 1 of 2 12 LastLast
Results 1 to 50 of 60
    Non-member Wallace's Avatar
    herts
    Unhealthy noise?
    Hi all,
    My engines got a grinding/whirling type noise? - It is intermitent, and comes and goes but mostly appears when i increase the rev's, and may disappear on tick over for a brief period.
    As soon as i kill the power to the engine it stops instantly too, appears to also only sound when the engine is up to temperature!
    At first i thought it might be coming from the flywheel (cars sat for a while and flywheel has rust on it!) but when i apply the clutch and put it into gear no change!
    There are also no obvious marks on the flywheel to suggest the starter motor either.
    I'm now convinced it's coming from the turbo, of which i assume is bad news and possibly starving the turbo of oil??
    Have a listen! - Any thoughts or ideas much appreciated??
    http://www.youtube.com/watch?v=HuvcMJvN7dw
    Re: Unhealthy noise?
    That doesn't sound good matey sounds like something is grinding away, Alex i note you mention turbo have you removed the oil feed to the turbo and cranked engine to make sure oil is getting to the turbo??
    also remove the air filter to the turbo and have a look for play
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    possibly something inside your filter when you refitted it?
    herts
    If you have a butchers on my project thread, i've taken a couple pics of the turbo and brief outline, in my opinion the turbo is still good............
    Having said that, NO! I haven't actually done as above! - I thought that because i've got the fecking leak (turbo drain to sump!) that oil must be getting through!
    I will definately do as above though James for sure............because yes it sounds terrible doesn't it
    herts
    Do you mean oil filter?
    If so, then yes i have checked and double checked and nothing in the filter!
    Haven't check the air filter, so will do that anyway, obviously doubt its go anything to do with the noise but be good to do anyway
    Sep 2005
    Parkgate Cheshire
    Ah sorry not looked at anyting previous. i wouldnt run it unless you have to. try turning the blades yourself. feel if it catches anything?
    Sep 2005
    Parkgate Cheshire
    Air filter sorry. see if anythings inside
    herts
    Cheers Tony
    Will do...........
    Member Thundercat's Avatar
    hi mate, drop the engine oil and see what you get. Had grinding noise before on a c1j that was stood 10 months outside and found water missed in the oil.
    Non-member Yellow's Avatar
    Jul 2009
    Portsmouth
    Mine sounded a bit like that after having a few issues with the breather system mainly missing restrictors I think. Sounded quite similar though.
    Non-member TNT ANDY's Avatar
    Quote Originally Posted by Yellow View Post
    Starter motor ?
    Without a doubt
    herts
    Thanks all
    I'll try and get it sorted during the week if not at the weekend!
    Then post what i find..................
    herts
    Can't stop thinking about it
    With regards to the startor motor........
    Am i right to assume its proberly "grinding" for 2 reasons:
    (1) Not seated properly? out of alignment?
    (2) The "solenoid" possibly faulty - not engaging/dis-engaging?
    Thanks again
    Non-member gimme5's Avatar
    Dec 2008
    north yorkshire
    whirling noise????
    could maybe be the release bearing, put your foot on the clutch pedal while
    engine is running and see if it stops
    whoops just read post right through
    Quote Originally Posted by Wallace View Post
    Thanks again
    I'de pitch for number 2 - the noise I can hear was very familiar to me after I've heard this many times on cars that start then when they release the key to stop engaging the starter motor and then it makes this noise on run down. I think it is the sliding teeth cog that is worn or needs lube.
    herts
    Brilliant
    Fooking hope its not chewed it to pieces - its new
    Hope it just needs some lube-ing up
    Cheers Andy
    Sep 2005
    Parkgate Cheshire
    Dont think its the starter, if its staying engaged it would squeal like a b***h permanantly, it wouldnt disapear when it idles then re-apear when yoou rev it. un bolt the tubo put the feed in to the return and run it, you'l know if its turbo or not then.
    herts
    Thanks Tony, thats just the sort of advice i'm after
    Seems an obvious thing to do now, but hey ho.......
    If i'm honest, i still think its the turbo too........purely just by the sound and the kind of location "i think" its coming from?!
    Will try and get things moving tommorrow night, but as is always the case work will probably get in the way
    Sep 2005
    Parkgate Cheshire
    Np if i was there and could hear it i'd know straight away, allways difficult from a million miles away
    Non-member 5teve L's Avatar
    RH12
    'kin 'el thats not a good noise, blip the throttle in the car & press the clutch down to see if it goes, could be release bearing.
    I hope it's not anything in the turbo as it would have mullered it by now
    Check the comp wheel is spinning ok as well once you have the filter hose off.
    I dissagree
    Sep 2005
    Parkgate Cheshire
    would be a boring world if people didnt.
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    Grab the compressor side of the turbo and feel for vibration, it shouldnt be too hot. You should feel zero vibration...
    I agree with Tonys method of removing the turbo and turning the engine over, wont take long to pull it off and do it either
    Best way to rule out the starter would be to start the car without using the starter motor...
    Non-member tiff_lee's Avatar
    Glasgow/Lincs
    Surely just remove the starter motor and look at the ring gear, if it has been catching to the point where it is making that noise it will be instantly obvious.
    I'm spit balling here - but I don't think you will see any 'missing teeth' etc, It is wear on the main shaft of the starter motor.
    Glasgow/Lincs
    So what are we saying here, the starter is still fully engaged once the car is started?
    herts
    Well i for one am glad theres different opinions - its given me food for thought!
    Im desperatley trying to finish off early today to get out there and find out what it is...........and fix it!
    I may very well be wrong, but i do think its the turbo! It just really seems to be coming from that area, then again as Steve says- if it is the turbo then i'll be a very unhappy chappy................
    As soon as i sort it, i'll post up what i've found..
    Massive thank you again everyone for the input
    Dartford
    I'd say check the restrictors in your breather pipes first fella
    I'd say I aint got a fapping clue now.
    herts
    Too late
    herts
    Ummmm kay.................just managed a couple of hours of play time!!
    Now proved to myself that there is oil coming through the turbo feed - as pic (1) - thats was from no more than 10secs of tick over!
    I removed the turbo, and started the engine, but can't elimate the turbo as yet! - running the engine without the turbo on is fooking loud and didn't want to piss neighbours off so will approach that at a better time.
    There is however, zero play in the shaft backwards/forwards & minimal up/down movement...........if i had to put a measurement on it, i'd say 3mm movement max?!
    As for the starter motor, well f**k me thats some bull****e getting that off isn't it
    The pictures say it all really.............so what do you reckon guys???
    herts
    Whats peoples thoughts then???
    Sep 2005
    Parkgate Cheshire
    we need to see the teeth on the gear of the starter motor, is the one way clutch working on the starter gear? the squeel can be the clutch, or the starter gear sticking out and not returning. check the gear turns one way and not the other, it will be a bit tight but you should be able to turn it one way.
    Sep 2005
    Parkgate Cheshire
    lol beat me to it.
    Dec 2009
    west midlands
    Now the starters off and i know its a pain in the arse because i took mine off the weekend gone isnt there a way to test it by putting a wire from the battery to the starter, im sure someone will instruct.
    Mat
    herts
    Sorry peps all sorts going on in the thread now
    With regards to the restrictors - I need help??
    Where should i look/start? - and what am i looking for?
    Any pics would be awesome
    herts
    Quote Originally Posted by Smokey View Post
    Mat
    Yes you can test it - 12v supply and link to the solenoid
    Be doing that tommorrow!
    Cheers Mat
    herts
    It turns both ways!
    Only way i can describe it is: turns one way with all the "drive gear"
    and turns the other way but JUST the teeth section!
    Talk to me???
    Yes you can test it - 12v supply and feed down to earth
    Cheers Mat
    Sep 2005
    Parkgate Cheshire
    does it turn one way, and turn the other but move outwards as you turn it?
  41. #41
    herts
    No! - One way with everything (shaft,drive gear/internals) & and the other way just the teeth...............but no movement in or out either way?
  42. #42
    get some jump leads, black lead on starter mounting flange and red wants to be connected where battery lead went. Then with screwdriver short across to where flat terminal is. Starter gear should shoot out and spin up. When you remove screwdriver it should stop spinning a shoot back in. Simple test!
  43. #43
    Dartford
    With regards to the restrictors - I need help?? TBH I really can't remember where exactly they are as it's been that long since I worked on a standard one!!! I've had a search round the site for a pic, but again, can't seem to find a pic.. You need someone who has access to dialogs to get a break down of the breather system
    hope this helps.
  44. #44
    Alex the restrictors for the breather system are placed in the tubes in the locations on the following pic's.
    Renault part number for the restrictors are
    6001007416 for restrictor between t piece and pipe to telephone hose
    6001007478 between T piece and inlet one way valve
    I don't see this being a restrictor problem though
  45. #45
    I would be tempted to jump start the car with the starter motor removed if the noise is still there eliminates starter.
    Clutch bearing??
    Hmmm another thought gearbox input shaft damaged?? was clutch friction plate aligned ok?? and torqued down??
    Just more food for thought really.
  46. #46
    herts
    James mate your an absolute diamond
    I'll look into that tght..........
  47. #47
    herts
    Clutch bearing??
    I'm not convinced its the clutch bearing, only because i took alot of care with these jobs, the clutch plate was aligned and torqued............but thats certainly not me ruling them out!
    Gearbox input shaft is a definate maybe!
    I'm going to do as said a couple times and start the car without the starter motor in place............ive just tested its functionality and everythings seems fine.....
    I'll get it sorted eventually, think a day off work may be required, cause by the time i get home it's dark and can't always be arsed
    Thanks again James......
  48. #48
    Sep 2005
    Parkgate Cheshire
    if you get a long screwdriver, and put it on the turbo when its squealing then put your ear on the screwdriver you will get a much clearer sound of the noise, then try on the gearbox housing(take care of the flywheel while its running) move it around different parts and you will hear it change. it should be quite clear where the noise is strongest.
  49. #49
    herts
    Cheers Tony
    i'll follow that idea when i have it running again.
    Tested the starter motor today,and its working perfectly well, given it some grease anyway..............suppose there is a slight chance it may "snag" when under load, but i doubt it to be honest.........
    Will try and leave work early tommorrow so i can get invoved again.......
  50. #50
    herts
    I've uploaded a video on my project thread - and guess what "no noise"
    https://www.rtoc.org/boards/showthrea...624#post208624
    The oil looked ok, the breathers were all present and correct!
    I did fit the starter motor before double checking, but was personally convinced it wasn't that..........i may be wrong!
    What i think the noise was, is the Turbo
    The new turbo oil feed (with the in-line filter), the hose is just too long.......causing it to kink and then hence starve the turbo of it's required oil.
    I've now positioned it precisely to avoid this again, and the noise has not reappeared, and i've had the car running a lot today........
    I shall call hose solutions on monday and post up what they say.......
    Thanks again for all the advice and i really hope this is the end of it
