To set the scene: So i have just finished rebuilding engine and it waiting to be put in put in next weekend.
engine spec: new standard liners, pistons, bearings, thrust washer etc etc head gasket, new high tensile bolts- the full works....
also has twin capacity i/c with oil cooler with sandwhich plate thermo switch
i have also wideband installed (not used to set up yet.- which i will be)
i'm sure its a standard size turbo, (i know should may more attention) i can never remember all i know has 360 thrust bearing.. etc
i have just checked the jets in the carb and they are as follows
main yet 130
air corrector .9
1st 1mm
2nd 1.2mm
My question : i realise every carb it set up differently dependent on the car, but does that combination sound about right..? if not what, in your (the discerning RTOC forum's) opinion, should it be?
What is your carb jets setup?
