Results 1 to 9 of 9
    Non-member 5teve L's Avatar
    RH12
    FPR
    Does it matter what FPR I use on my F7P turbo ?
    I didn't have one on the F7P except an FSE & didn't fancy using that.
    Today I picked up a FPR off a volvo 850 T-5 which is a 3 bar reg & fits in my rail, would this be ok to use @ 1 bar boost ?
    ta
    Steve
    Oxfordshire
    Re: FPR
    ta
    Steve
    I don't see why not, just connect the ref pipe to the plenum. That's assuming that it was mapped at 3 bar fuel pressure, or is yet to be mapped.
    RH12
    Re: FPR
    It's got a fast chips generic map at the moment so I assume so.... well it will have once I've plumbed it all in & tested it
    Jan 2011
    Re: FPR
    im running 2.8 bar with vacum pipe off the fpr so 3 bar sounds about right
    RH12
    Re: FPR
    Quote Originally Posted by sammo_gtt View Post
    Re: FPR
    ta
    Steve
    What was wrong with the fse job?
    RH12
    Re: FPR
    They aren't exactly known to be the best, plus it was off an N/A lump.
    Mar 2011
    Re: FPR
    the standard f7p reg is 4.0 bar IIRC
    i would recommend a rising rate fse reg on a 1:1 ratio
    i think sytec make them.. ill have a browse through and find you a link from somewhere
    coops etc run them and dont seem to have too much problem
    Mar 2011
