Results 1 to 2 of 2
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Bosch vp 30/44 edc faults
    Anyone got any experience with these. Its got the usual p1664 p1564 fault codes, non start, pump is supplying fuel but minimal.
    Sorry, its on a ford transit D3FA engine.
    Portugal
    Re: Bosch vp 30/44 edc faults
    Hi, it´s a common problem in most of vp44, you need to change the pump ECU, or you can fix it changing one little transistor inside of the pump ECU, you can replace it with one IRFZ44.
    Hope it helps
