Results 1 to 27 of 27
    Non-member TNT ANDY's Avatar
    CR Turbo's - anyone used them ?
    Need to get mine looked as there is minor damage to the entry compressor turbines.
    Just wondered if anyone had had dealings with them?
    Re: CR Turbo's - anyone used them ?
    Steve aka 5teveL has had quiet a few dealings with them with various turbo's he has had from them
    norwich
    spoke to them this afternoon for some info, very helpful
    wont go far wrong andy
    Non-member rs250nut's Avatar
    Had a couple of turbos off them top people.
    Non-member Junglist's Avatar
    Dec 2008
    Chester
    i got my turbo from them ,, very helpfull and good price
    Thanks everyone - been speaking to them - good common sence people and can get your turbo picked up, and dropped back to you for £15. Can't go wrong.
    Committee Member
    North West Regional Area Rep
    BluntyR5GTT's Avatar
    Nov 2009
    Stoke-on-Trent
    have you spoken to vince hes a really good guy when it comes to turbos at cr
    Non-member 5teve L's Avatar
    RH12
    I found them good to deal with @ CR . I usually deal with Mark.
    Non-member stu21t's Avatar
    i got a new wastegate assembly for my t34 from them when no1 else does them.
    and loads of people on passionford use them
    Non-member Nayls's Avatar
    Weymouth
    i've used them before nice blokes!
    one of them knows glenn T,he spoke about him and his R11 when i was there last.
    Right you guys - between you me TNT Ross and a few others from the PPC brigade, CR seem very reliable.
    My turbo has a little front end damage ......
    (bought it like this last year) and after some thought have decided to let them have a look, as I thought this may not be the best thing to be having running round just before the inlet side of an engine.
    So I made a turbo coffin...................
    Closed her up................................
    And will be ringing CR Turbo's up tomorrow morning paying them £15 for them to pick up on the same day and get back to me by Tuesday / Wednesday for the good / bad news.
    I'll keep posting.
    Phoned 9.30 am. Picked up by fed X 12.00.
    Got a phone call from Mark @ CR at about 3.30 today. My turbo is a T25 turbine (exhaust) side with a T3 60 trim compressor (air side).
    After a bit of a chat he said it would be quite laggy as it is, but as I'm looking for a figure of 200bhp he could fit a smaller compressor wheel with as part of the refurb' as it needs replacing anyway due to damage.
    Anyways, he reports that the unit is salvageable with a new compressor wheel, a new shaft and new oil seals.which will be less laggy and will comfortably support 200bhp. not only that, I'll have it back by weekend.
    Can't argue with that
    Nice one Andy, what sort odf cost was that??
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Got a phone call from Mark @ CR at about 3.30 today. My turbo is a T25 turbine (exhaust) side with a T28 compressor (air side)
    so an A/R .42 is a t28 comp size?
    so what was the comp side on my t25 which had a comp side of A/R .48 ?
    http://www.turbobygarrett.com/turbob...tech102.html#b
    Loads of decent info on here.
    Feb 2001
    Rohtang pass
    yes ive seen that in short its saying the bigger the housing=more flow.
    but what i dont understand is how can a full t25 have a comp housing of .48 and a bigger t28 turbo have a smaller comp housing of .42 ?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    It doesn't, the size is respective of the style. It's a ratio, not a unit of measurement. 0.42 T3 is bigger than 0.42 T25, not the same size
    £350 spondoolies, but although not super cheap - I do have a feeling of top quality here. I've done the back door deals for a number of years now and only been dissapointed.
    No pun intended.
    Feb 2001
    Rohtang pass
    im never going to understand this ratio lark
    Mark @ CR (these guys used to do a lot of work for GT Tunning, BBT and K-Tec back in the day) has been back on the phone today and here's what's appertaining.
    I'm basically going to get an as good as new turbo back, it's been fully disassembles cleaned and put back together with all new nuts and bolts etc with the following.
    - New 360deg bearing (there is very little benefit of roller bearings on smaller turbos according to them guys).
    -new oil seals
    -I think he said new pistons / piston seals.
    -new Compressor dropped from a 60 trim to a 50 trim
    -new compressor housing to suit.
    I think that was it.
    The reason he dropped from the 60 trim T3 to the 50 trim T3 was to reduce lag, he knew what BHP I was after and the smaller 50 trim would happily do that, so a less laggy turbo with the 200 BHP I'm after.
    With the .49 T25 rear and this 50 trim T3 this should ideally be quite punchy, not too laggy and not suffer top end too much.
    I'll post some pics up as soon as I have it. I should have it back tomorow, not bad going considering I posted it to them on Monday.
    The price - £407.00 all in That includes delivery
    norwich
    update please ,some piccys would be nice also. bluepeter stylee
    As you wish BK
    The T3 Compressor 50 trim .42 AR
    The T25 Turbine .49 AR also Heli-coiled
    Machined and heli-coiled exhaust manifold flange.
    All supplied with new oil return gasket and 8 x studs
    Banned
    Nov 2008
    dont no
    looking good hay can see that comeing when on the car mate
    Quote Originally Posted by raider_gtt View Post
    Hope so - it's been a long time coming. Thanks for the comment. next 4 weeks and I should be back.
    norwich
    "jizzed in my pants"
    looking very nice
