Starting motor dowels
Hi,
Finished putting everything back together on the 5 yesterday after changing the head gasket, and turned it over - horrible sound
Could you tell me which hole the dowell is supposed to go in on the starting motor - we had two made-up as there weren't any on there, put them in and now it sounds even worse than it did before!
Committee, South East Regional Rep
Re: Starting motor dowels
As your looking from the passenger side of the car it is the top left that has the dowel should be in
Ah ha - thank you, I think theres one in both holes which would explain everything
are you sure? im certain that the dowel in mine is in the hole nearer the top corner of the starter im going to have to recheck myself
does anyone have a picture identifying the dowel location.?
Yep a pic would be really useful
Loose Bolts Tuning
it's not a gt gearbox, but it's from a 5 so the dowell will be in the same place, it's nearest the top hole that is nearest to the bulkhead-
Your right
Not a very good pic but you can just see the dowel. Ooops Sorry
No problem - thanks for your help
i knew i was right was still questioning myself though
