Page 2 of 2 FirstFirst 12
Results 51 to 67 of 67
  1. #51
    Member clee's Avatar
    Derbyshire
    Re: R21 txi disc help
    No ,you're 100% right .
    I was in wheel mode , just drawn up some hubcentric spacers for a guy and had that figure in my head
  2. #52
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    Quote Originally Posted by clee View Post
    No probs
  3. #53
    Derbyshire
    The point I was trying to make is don't make them dead size to the male bit or they'll be a bitch to fit and get off
  4. #54
    Aug 2009
    Newcastle
    Today i have been having a measure up, moving calliper back a little and messing with wheel spacers.
    My 16" arrows will not clear the callipers, im have been trying a 3mm wheel spacer on to see how much i can pull the extender back for my wheel to be clear.
    3mm was not enough wheels still catching, and to top it of i have scratched my calliper. I masked them up and was so careful when nipping the wheel up, but on taking it back of its scratched the calliper
    To get this to work with the momo 16" alloys im going to have to pull the extender back 3mm with washers and probably use a 3mm wheel spacer .
  5. #55
    Aug 2009
    Newcastle
    Update on the brakes, i bought the lancier discs, i have had the centres machine and elongated the stud holes. Thank god they fit, i have fitted an m12 washer to pull the calliper back a little to line up, so the disc and callipers are bang on centre
    Next problem, im probably going to have to run 5 maybe 6mm spacer to clear the momo alloys. I think the best way to do this will be buy a full stud kit for the car, it will make taking the wheels on and on alot easier.
    2nd problem, my brand new goodridge hoses are to short on the front on full lock so im either going to have some longer pipes made or use a banjo kit with a 45* in it, which just might work
    Oh the joys
  6. #56
    norwich
    glad your getting there philknow it wont help your wheels ,but os8472 came over last sat and tried his 15" rims, fitted a treat , no problems with clearance what so ever
  7. #57
    Non-member J8TRO's Avatar
    Stourbridge
    Mate, i know you must be thinking in some respect............."i wish i'd never bothered" but keep at it, it will be worth it.
  8. #58
    Aug 2009
    Newcastle
    Quote Originally Posted by HAndy View Post
    Its the arrows, i had to grind the back callipers to get them on the back but got away with the front, until now that is. Yet the Williams wheels sail on , i have been told 5 spokes generally have alot more meat on the inside edge of the spokes.
    What style were your mates?
    What did you do with the brake hoses, the goodridge are now to short?
    Also when searching for a stud conversion what did you end up going foe andy?
  9. #59
    Aug 2009
    Newcastle
    Quote Originally Posted by J8TRO View Post
    A little
    New rear discs, bearings, pads another rear calliper, wrong front disc's, new ones machined to fit, wheels now not fitting, spacers and stud conversion kit on the cards, calliper scratched, front pads modified to fit calliper and now my goodridge hoses are to short
    Yeah mart was so right
    Captain everything on this car has been hard work so im used to it now
  10. #60
    norwich
    i replaced the lot on mine as they where old, but in your case i would use the existing connection from steel or copper to flexi, and buy longer braid hose and new caliper connection,
    http://www.rallydesign.co.uk/product...oducts_id=1530
    cant remember what thread the oe connections are , if they are a m10x1.0 then perhaps one of these
    http://www.rallydesign.co.uk/product...oducts_id=1528
    http://www.rallydesign.co.uk/product...oducts_id=1526
    ollies wheels are speedline turini's , he's got a picture of one on my car up close, about 4-5 mm clearance
  11. #61
    norwich
    phil ,not sure what you mean by stud conversion?
    mine are still 4x100, not running any spacer plates
  12. #62
    Aug 2009
    Newcastle
    Yeah multi spokes then
  13. #63
    Aug 2009
    Newcastle
    No, i read you swapped bolts for a stud and nut conversion, just wondered what you used in the end?
  14. #64
    norwich
    thats on my to do list, just got bolts at the mo, intending to weld in the stud kit into the back of hubs, later this year once the beast is up and running ,and the rest of the niggles sorted out
  15. #65
    Aug 2009
    Newcastle
    Great, now i will do the complete opposite Only jocking
  16. #66
    norwich
    ollie has put up that caliper/wheel piccy on my project thread at last!!
  17. #67
    Aug 2009
    Newcastle
    Yeah had a look, multi spokes seem to be the best for clearance. Like i said the williams wheels are fine.
    Should be getting a stud conversion kit, then a measure up for spacers on the front.
    I also look at the banjo you have on, it looks like a 90* then the brake pipe is put round the front of the strut, is that how you have done it?
    phil
