Results 1 to 4 of 4
    Non-member Misky's Avatar
    Oldham, Greater manchester
    coolant pipes
    How many pipes are there for the phase 2?
    Sourced a good condition full set but he needs to know how many pipes there are and where they go so he does not miss any so far i can think of
    bottom rad hose
    ones that come off the header tank
    anymore?
    Cheers for the help guys.
    Re: coolant pipes
    1) Top rad hose,
    2) Bottom rad hose,
    3) Turbo top from carb base,
    4) Turbo bottom from water pump,
    5) Water pump to swirl pot,
    6) Heater matrix to swirl pot,
    7) Swirl pot to header tank,
    8) Header tank to heater matrix,
    9) Water pump to inlet manifold,
    10) Inlet manifold to carb base,
    Can't think of anymore hope the above helps matey
    Re: coolant pipes
    Excellant! mate cheers for the reply!
    Banned
    Weymouth
    Re: coolant pipes
    mate i'll get looking should have a full set for you though bud sure i can make a full set from 2 cars, i'll get in touch later
    ok here goes
    think this is the lot
