Results 1 to 8 of 8
    Oct 2010
    2.5 inch downpipe onto a scorpion system?
    Hello all
    Will a 2.5" ktek downpipe mate up with the standard size turbo elbow and the standard size scorpion system im assuming it will be 2 and a quarter inch?
    Looking at a buying a 2.5" downpipe as it has a much needed lambda thread welded into it.Thanks
    Member Woznaldo's Avatar
    Canberra, Australia
    Re: 2.5 inch downpipe onto a scorpion system?
    It will definitely hook up to the std elbow and probably hook up to a std system but, a quick call to K-Tec would let you know for sure.
    Committee Member
    North West Regional Area Rep
    BluntyR5GTT's Avatar
    Nov 2009
    Stoke-on-Trent
    yes they go on no probs iv got the exact set up on mine, i also had the turbo elbow machined out
    hampshire
    my experiance of that set up, is it blows more that a ****ty hooker thats jus gettin paid 10x her usual rate
    Non-member KeefaGT's Avatar
    Aug 2009
    Kent
    Have just tried to fit my Big Jim (2.5") downpipe to scorpion (2 1/4") system today and have just given up It seems impossible to get a seal so you might be dissapointed m8.
    Has anyone solved this problem before without fitting a sidey?
    Classifieds Moderator
    Mar 2004
    Quote Originally Posted by KeefaGT View Post
    yep, had a guy chop off the flange on the zorst and slide over a slightly larger one..
    Non-member Adam 005's Avatar
    Dorset
    my scorp would not line up flange was to small for larger cross over pipe
    Aug 2009
    Kent
    New flange it is then
