Results 1 to 8 of 8
    Non-member REGGY5GT's Avatar
    Nov 2009
    shropshire
    Second water temp sensor??
    Right, i have the standard temp gauge in the dash and a aftermarket gauge in the centre vent, i stupidly thought id T into the standard temp gauge wire for the aftermarket gauge but all this did was kill the supply to the standard gauge, so the other option i have is to fit another seperate temp sensor in the block or head but the problem is where?? do any of the b18ft gurus know of any blanking bolts i can use to put the sensor in?? thanks in advance
    Non-member 5teve L's Avatar
    RH12
    Re: Second water temp sensor??
    You can get a kit that you fit in the top rad pipe AFAIK.
    As Steve says find out the id of the top rad hose pipe, and the thread of the sensor and then just buy to match.
    Non-member TrixNFlix's Avatar
    Preston
    32mm
    Non-member SCHWARTZ's Avatar
    Wallington south london
    something like this. May be cheaper elsewhere tho.
    http://www.demon-tweeks.co.uk/Perfor...r_Kit/812/1843
    Nov 2009
    shropshire
    how of me,lol, totally forgot these existed, thanks guys
    Nov 2009
    shropshire
    bought these just, they should do the job, bought a 34mm one so i dont restrict flow too much, 32mm will stretch on i rate, sensor is same make as my gauges so calibiration shouldnt be a problem,
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    thanks again for the heads up chaps
    Non-member sieger's Avatar
    assen city
    i also got 1 fitted, black thingy fitted in the hose, don't forget to run a groundwire from the adaptor
