Results 1 to 7 of 7
    Non-member TrixNFlix's Avatar
    Preston
    Engine bearings
    Just stripping down one of my spare engines, and ive just taken the bearings out which look in great nick, anyways was hoping to find a std or .25 mark on the underside so i could determine what size they were. All that is there is two part numbers, followed underneath by this marking:
    - Fm 1 11
    the 11 is located on its side.
    Anyone got any ideas
    Mar 2004
    Salford (manchester)
    Re: Engine bearings
    You could just measure the crank, have you got a mic?
    Preston
    Re: Engine bearings
    Ive got a vernier but i dont think that will be accurate enough. Any suggestions to a cheap micrometer?
    Member clee's Avatar
    Derbyshire
    Re: Engine bearings
    vernier will be accurate enough for 0.25 mm
    Preston
    Re: Engine bearings
    Quote Originally Posted by clee View Post
    vernier will be accurate enough for .25
    Lee what do you use?
    I need 3 decimal places.
    Derbyshire
    Re: Engine bearings
    A dial or digital vernier will be needed but accurate enough to spot a regrind .
    Preston
    Re: Engine bearings
    Well the vernier was a bit hit and miss but
    ended up with :
    all big ends 48.02mm ! tolerance is between 48.00 and 48.02
    main
    Mains were more difficult to measure with multiple different outcomes when using the verniers
    all between 54.76mm- 54.83mm tolerance is between 54.785mm - 54.805mm
    So overall im pretty happy with the digital verniers, and as Lee said i can easily tell that its a standard crank in very good nick.
