Results 1 to 15 of 15
    Non-member 5teve L's Avatar
    RH12
    F7P/R engines
    I have found an engine with most of the parts I need to fit it to my car (engine loom, mounts, alt & starter), the only part missing is the head & poss some hoses, can I use a different head from another engine like the 2l ?
    There isn't much info in the F-series section on exactly what I need, a few people have sent me PM's on most of the parts( which I'm greatful for), is it best to buy the whole donor car or can I do it the way I'm going above ?? Bear in mind I will be rebuilding to turbo spec & it will be on adaptronic.
    .... I have had a look for a 19 or valver but there aren't any near or they are expensive since I will be just ripping it apart.
    Re: F7P/R engines
    i know where there is an f7p in good condition in scrappy near me.
    If your using an adaptronic you won't need the majority the factory loom.
    Non-member r5 rich's Avatar
    Romford, Essex
    Re: F7P/R engines
    I got a head from a f7p sitting in my car. comes with no cams etc and come with my car as a spare.
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    Re: F7P/R engines
    Steve wanna buy my spare F4R engine mate?
    Its James' old engine from the 172 conversion he never did
    RH12
    Re: F7P/R engines
    Bit far for me to come & check it out really, can you dig out a name or number though please
    Quote Originally Posted by r5 rich View Post
    Not alot of good without cams etc, cheers though.
    Spooky, PM
    Re: F7P/R engines
    Non-member rs250nut's Avatar
    Re: F7P/R engines
    If you are going with the valver 1800 bottom end you could always use a willy head with bigger valves of the megane head which is bigger again on the inlet side. I would imagine the cams in the willy head would be of a higher lift aswell. Not sure which of the heads flow better though.
    RH12
    Re: F7P/R engines
    I have sourced an engine now, plus a few of the other parts I need.. Just need to get saving to pick up the rebuild parts
    Re: F7P/R engines
    Definately good to go for williams valves , wouldn't both with megane head unless you want to enlarge the exhaust outlet unless going for a lot of mid range torque. Could go for megane bottom end if you find one cheap enough, same as the williams bottom end will increase the torque a lot more however how long the gearbox lasts who knows.
    Romford, Essex
    Re: F7P/R engines
    means you can source yourself a nice set of piper cams and pulleys
    RH12
    Re: F7P/R engines
    Which I won't need as I am going turbo
    Non-member Logg's Avatar
    Re: F7P/R engines
    Maybe some adjustable cam pullys would be handy Steve. For gaining the best set up.
    http://cgi.ebay.co.uk/Renault-1-8-2-...item3361effa56
    Re: F7P/R engines
    Standard cams are fine for what you are after, unless you want to start chasing scoff for times.
    norwich
    Re: F7P/R engines
    Quote Originally Posted by Logg View Post
    thats what im running with, are well made and are a 100%stronger than the piper items,and a fraction of the cost, had no issues with the seller either
    norwich
    Re: F7P/R engines
    i went with some mild pipercams as the were cheap, but as said o.e cams would be up to the job with a turbo conversion, catcams do a set of turbo cams for the f7 (high lift /very little duration ,but a lot of money
