Results 1 to 47 of 47
    Non-member 5teve L's Avatar
    RH12
    Options..
    Following on from my thread on the engine failure I'm a bit lost what to do next.
    Options so far.
    1. Over-bore the steel liners @ £22 a bore, fit over-sized forged pistons (approx £530) & go for low comp which should give me an in-between comp ratio due to the block being decked (I think thats right) which would prob be pretty good for big power.
    2. Start again & rip the cam out, go back to cast liners (£150) with standard spec forged pistons (£530), get the whole lot lightened & balanced @ a cost of £240 & be stuck with a scrap block with 3 decent shortened steel liners.
    Both builds will require headgasket, bolts, sump sealant etc, etc...
    I am hoping to get started with buying parts over the next few months so this certainly won't be a fast build due to having a family, if I get it back on the road before RTOC pod day (or Phil ) I will be happy...
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Options..
    How is the block looking?
    Non-member shaggy's Avatar
    Re: Options..
    Options so far.
    I would go with option 2 steve. it must be a big ****er for you at the mo
    Re: Options..
    id go with option 1(just to be awkward) If this isnt going to happen again with the steel liners and would give you slightly more cc's
    RH12
    Re: Options..
    Not sure, will let the machine shop look at those hairline cracks...
    I'd prefere option 1 but Prob be going with option 2 though as any cracks can't be good
    Re: Options..
    looks like if the block is no good thats your only option matey
    Non-member philr5t's Avatar
    Dec 2008
    tadworth
    Re: Options..
    Options so far.
    id go with a clio lump
    RH12
    Re: Options..
    Quote Originally Posted by philr5t View Post
    Looking at best part of 3k for that phil as i looked before... Lot's more involved as well.
    Oct 2004
    Somerset
    Re: Options..
    ...id buy an evo steve instead........
    Dec 2008
    tadworth
    Re: Options..
    how much do you want to spend on this rebuild mate
    Dec 2008
    tadworth
    Re: Options..
    it was to reliable jesus
    Oct 2004
    Somerset
    Re: Options..
    ...sorry steve,couldnt resist..., option one sound a plan, "if ye seek high boost..ye see high bills"...
    RH12
    Re: Options..
    Thanks. Matt
    Phil, as cheap as i can, i'm thinking it won't be any cheaper than £1000 though
    Non-member TrixNFlix's Avatar
    Preston
    Re: Options..
    Steve have you considered the b18ft route? 8v, logg manifold, efi, granted the inlet has Volvo on it,( James will be wincing as he's reading this) but costs will be kept down. I'm starting to bore myself now just an option matey.
    Dartford
    Re: Options..
    Steve what are you looking to do with the car?? That's the first thing you want to sort... Fast road, all out drag car, every day car???
    My old engine that I built with Standard everything with L&B, low comp pistons, cam, and port matched head.. That see me run a 12.2 @ 115 without the gas.. (I'm sure Scoff said it was about 250bhp according to his 1/4 mile thingy) Only reason I went forged, was because I new I wanted to run quiet a bit of gas.
    RH12
    Re: Options..
    How do's Dave, I'm looking at fast road/drag car, it's not a daily but I would use it on the road sometimes.
    I was thinking forged just to be on the safe side TBH.
    I'm not even sure I can save the block now after seeing the cracks in it
    I suppose I could go standard & then spend the extra cash on aftermarket ign...
    Dartford
    Re: Options..
    I would just go standard imo n keep the boost at sensible levels on the road, that's what i always do, obviously in the heat of a battle maybe a lil more I still even kept the liners standard with the gas, lasted quiet a while longer than I expected! Still though, only 1 failed, that's not to say that something didn't go wrong on that run, never bothered to investigate as I always thought they wouldn't last...
    You get away with a lot doing 1/4mile racing as it's only a short blast..
    You start building high spec engines and you will spend lots of money trying to keep it maintained!
    RH12
    Re: Options..
    Whats sensible on the road then Dave TBH I used to run around 1.5 bar on the road, this time I was only at 18 psi, something was deffo not right..
    Re: Options..
    Id go for standard liners meself unless your planning on running lots of gas. If the blocks badly cracked it bin it imo
    Dartford
    Re: Options..
    A standard car
    Well you've also got to think about what a normal everyday clutch can handle, start going paddle etc and they become harder to drive and dont last..
    Thing is, is if you build a decent enough engine u'll see around 200 at about 18 to 20 psi (with a T28rs which is what I run).. Make it as efficient as you can, that's the key and it will make good power under less strain.
    I also see that you want to go EFI? thing is, is if you do then I'd build a higher comp engine. Maybe pick another engine up (standard 1) and just throw it in and rebuild you MSM one (as long as it's salvageable) for the EFI conversation. You'll prob get an engine 4 about £100.
    RH12
    Re: Options..
    Ok, after a bit more investigating the block is deffo scrap, has a crack on the outside that looks like it's been leaking a while..
    Non-member markey b's Avatar
    Bury St Edmunds
    Re: Options..
    i take it your engine is a skimmed deck msm one too?
    mine doesn't even have forged pistons and its been fine since i've had it (got it in 2005) running 27psi
    only problems i've had are ones that i've caused...
    why get forged pistons as standard ones are ok as long as you get fuelling right, they are just an added expense when it does go pop
    Dec 2008
    tadworth
    Re: Options..
    good job i have good eye sight to spot those crack
    Re: Options..
    if youre thinking of efi as well as needing a new block i would seriously consider B18ft'ing it
    Dec 2008
    tadworth
    Re: Options..
    A standard car
    hi steve some info for you that may help you if you are looking for an engine still as a runner until you build up another the last time i was down at mikes aka phase 1 16v place he had at least 5 or 6 complete engines that are ready to run and several more that could easily be built up to make a good engine
    i think this will probably be your best option to get you up and running again soon mate as there are a few to choose from
    RH12
    Re: Options..
    Was thinking 16v (F7P) myself....
    norwich
    Re: Options..
    deffo the cheaper route for bigger /more reliable /power, and cheaper than the f7p/r or f4 route that said ,16valves and cross flowed is the going to give you the bigger power output , but at price
    RH12
    Re: Options..
    Thing is, the volvo lump hasn't been proven to be that fast without throwing a bit of cash at it either.. custom cam, etc etc all adds up.. I will be certainly looking into a few options, thought about VAG but after having the S3 I hated the gear change on that..
    So we have.
    Rebuilt C1J
    Volvo
    f7p/r or f4
    VAG
    Now since I also hate the carb & renix unit , & was thinking of going EFi on my C1J anyway, it makes sense to just go for an engine conversion TBH....
    Re: Options..
    I went for the volvo as it was the cheapest to buy and all ready turbo'd also nice and simple conversion cost me about £700 in all and also sold a few c1j parts starter flywheel etc and got some money back. Also there seems to be the most help on hand with the conversion which id all ways good
    RH12
    Re: Options..
    I think I need to pop out in your car & also look into options/build specs...
    I also think Mark needs to pull his finger out so I can get out in a big power version..
    norwich
    Re: Options..
    16valves for the win
    Re: Options..
    I should have mine running nicely by next meet so can take you out then youre welcome to have a go yourself if you've got insurance. mines only a small power build but would defo like to see marky marks build to see what they can do.
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: Options..
    16v....depends what motor.......20v ftw...
    norwich
    Re: Options..
    16v....depends what motor.......20v ftw...[/QUOTE]
    mmm...not renault though is the o2j vag box all that much better than renault in o.e form,unless you through money and development at it, and cable gear selector is a deffo no,far to much aggro for me anyway, with the engine in the back
    norwich
    Re: Options..
    just out of interest what are the benefits of the f4 over the f7 engine anyway, once you take away the variable valve timing bit, are the cams anymore suited to turbo appplication on lift /duration, are the inlets /exhaust valves any bigger, are the inlet manifolds better flowed, does it share the same bottom end grunt as the f7r and does it respond better top end (rev wise)tha the f7p i dont know ,but im sure somebody does
    Preston
    Re: Options..
    As we keep telling him, his is the benchmark, people might sit up and notice this engine then.
    norwich
    Re: Options..
    i was going to go with the b18f ages ago, had the engine lined up to go in
    it was just that the compression was all in the the pistons and not knowing there limits ,even after searching the volvo 480 owners club forum it was a big grey area,that and cam options and of course 16 valves compared to 8 , but all respect to mark for giving it ago
    Re: Options..
    phil you've alway's had a good eye for cracks that you could put your cock in lol
    Re: Options..
    Quote Originally Posted by Dave..H View Post
    some not visible to the human eye
    Re: Options..
    theyre getting over 300bhp on the 480 sites with these lumps
  41. #41
    Dec 2004
    Aylesbury
    Re: Options..
    Don't worry boys, it may all seem its gone quiet on the Volvo front but things are happening behind the scene's
  42. #42
    Preston
    Re: Options..
    Gets some pics up mark, i need some more motivation.
  43. #43
    Dec 2004
    Aylesbury
    Re: Options..
    I will be soon mate, at the moment its looks alittle less complete then last time as it has nothing in the engine bay at the moment
  44. #44
    Re: Options..
    is this going to be a purley drag car or will it be coming to the surrey meets etc...?
  45. #45
    RH12
    Re: Options..
    Looking like F7P
  46. #46
    norwich
    Re: Options..
    Looking like F7P
    go for the f7r out of the 2.0 16v megane coupe , the head has 2mm bigger inlet valves than the f7p as standard, and fit the f7p crank /volvo 480t crank, also has no distributor , easier for stand alone ecu
  47. #47
    norwich
    Re: Options..
    same engine near enough as the clio williams , but without the big "williams" price tag on the end
