Results 1 to 12 of 12
    Non-member SCHWARTZ's Avatar
    Wallington south london
    fuel pump not priming
    is the fuel pump supposed to prime when the key is turned to the second click? Mine never has and it takes a good few turns of the engine to start.
    Dec 2004
    Aylesbury
    Re: fuel pump not priming
    Did you wire it up to the original fuel pump relay mate or is it wired up like the volvo?
    I have taken the wire from the volvo loom straight to the fuel pump relay and removed the thick white wire (r5 loom) from the relay
    Dudley
    Im fairly sure the pump doesnt activate untill the engine is cranking.
    Andy
    Non-member TrixNFlix's Avatar
    Preston
    Quote Originally Posted by Andyhot View Post
    Andy
    yep it srarts pumping when it starts cranking i just thought it may prime before tho. Guess not
    Preston
    Mine took 2 turns and fired, realy quick
    mine used to now it will crank for about 5 seconds then the regulator squeaks then it fires il look into that as that could also be causing it as not letting the pressure build up.
    bracknell
    Andy
    got to be something to do with my regulator then, il look into it cheers chaps
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    I thought this was the cause of all my problems, whacked on a walbro 255 as andy recommended, it fires on the money every time, but it still primes the pump going back from crank to off.
    I guess you have fitted a bigger pump?
    i have a mk1 golf gti pump that is up to the job, im going to look into the reg.
