Results 1 to 19 of 19
    burton on trent
    whos used por15
    ok.. gota few areas on my 205 which had rust on however after being cleaned and painted the rust has come back though, just wondering if there is any por15 style product that will rust proof which is overpaintable with 2k paint.
    Ideally white would be ideal..
    Non-member 5teve L's Avatar
    RH12
    Re: whos used por15
    Think it was JRP..
    Re: whos used por15
    Think it was JRP..
    Yeah was JRP he swears by the stuff, I think you can get it in white
    Apr 2002
    Re: whos used por15
    Yes, but he's got Tourettes
    Jul 2003
    Re: whos used por15
    Justin Fisher or J£$.. whatever it is is a BIG fan of the old POR15!
    I did the back of my car last year & it looks good!
    Non-member robbie506's Avatar
    liverpool
    Re: whos used por15
    does anybody know a good place to get por15 im going to grind the rust out later this week. and whats the best process once its ground out??? im paying somebody to finish it off but as im payin by the hour i need to do as much as possible myself.
    sorry about hijacking the thread
    Non-member TrixNFlix's Avatar
    Preston
    Re: whos used por15
    Classifieds Moderator
    Mar 2004
    Re: whos used por15
    dont get it on anything smooth without a good key, it will peel off...
    ruff is best
    burton on trent
    Re: whos used por15
    hmm.
    Im going to get some of this stuff, tehn apply an etch primer and then see if i get away with chucking some 2k paint over the top.
    Non-member Shane P's Avatar
    Jan 2006
    Re: whos used por15
    Quote Originally Posted by robbie506 View Post
    http://www.youtube.com/watch?v=SvcepMwqmZs
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Re: whos used por15
    Its the lickity splits and the winity win of gear that..
    i found best results i have had i used marine clean, then metal ready then the por 15
    You may find the post on here about removing it from your hands!!! you cant so wear gloves
    Nov 2001
    Hogwarts
    Re: whos used por15
    ****ing right you ****
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: whos used por15
    ai that i am,was sceptical when i heard about this paint,but it works and i think many a 5 an classic car would benefit from this,long as you follow the correct procedure...and as been said its not a fan of smooth metal surfaces...they do different primers etc for different finishes....
    also frost as of late i have found to have very poor stock,found this new site-
    http://www.holden.co.uk/
    and the metal ready is worth every penny to...
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: whos used por15
    Whats the crack with this stuff then? If i've removed the surface rust will it prevent it coming back?
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Re: whos used por15
    Yes Ashy, i had a rusty GTT battery tray, removed the loose surface rust, applied the marine clean, then metal ready, then the POR-15 and 3 years later its still as good as the day i appled it !!, it really is that good
    Re: whos used por15
    Ive got some on order, th metal ready is out of stock at the moment though
    burton on trent
    Re: whos used por15
    what im interested in , is whether or not you can apply the po15, and then instead of using a top coat like chasssis black or similar if you can use a 2k paint straight over the top.
    Kilbirnie
    Re: whos used por15
    no you can't put 2k paint over the top.
    I used por-15 but had to use a barrier coat made by u-pol to stop it reacting before appliying 2k.
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    Re: whos used por15
    When my car was done, it was 2 pac primed and then painted.
    By the little tins, they look like model car size tins. I was told to do this from jrp and still have some left over.
    Put some gloves on to, it took me about 2 weeks to get it of my hands.
