Results 1 to 16 of 16
    Non-member xchipx's Avatar
    Sep 2010
    Carb now rebuilt. Car wont idle when you brake ?
    Well have just stripped and rebuilt/refurbed the carb.
    The car actually starts in the cold, and idles now
    However, the idle is very very lumpy (without the choke on ) at any temperature.
    If the car is rolling, and you put the clutch down, or put it in neutral - and at the same time you are slowing down by braking, it makes the engine cut out.
    If the car is stationary, at idle, pressing the brake DOES NOT make the idle change.
    So in my theory it is something to do with gravity. There are no probs under throttle at all, only idle ( or cruising with a trailing throttle )
    Could it be when braking while moving that the fuel is moving about in the ( carb, fuel lines, pump, fuel tank ) that is starving the engine or making it overfuel ?
    The carb was fitted with a new float valve, and the original float appeared to move alright.
    Thanks again
    Mark
    edit (yes i know, the title is meant to be carb, not car :P )
    Non-member Fishey's Avatar
    Oct 2009
    Gloucestershire
    Re: Car now rebuilt. Car wont idle when you brake ?
    Quite possibly the one way valve on the back of the inlet manifold, i had exactly the same problem and that is what it was!
    Tipton
    have you actually tried winding the idle mixture screw out - what effect does it have?
    walsall
    replace the vacuum hose from the brake servo to the rear manifold id put my money on that hose
    Sounds like an air leak.
    Sep 2010
    Tried playing with mixture screw today, wound fully in or all the way out, not the slightest bit of difference ?!?!
    Sep 2010
    Quote Originally Posted by bye_all_c_ya View Post
    If its the one i'm thinking, its quite a thick hose, right ?
    Sep 2010
    I dont think its the hose leading to brake servo.....
    Pressing the brake when not moving does NOT make the car cut out.
    Pulling the handbrake when rolling, DOES make the car cut out .
    Seems like something to do with gravity ??? Its nothing major, but it is starting to piss me off. Help appreciated...
    Fuel pump? Pressure regulator ? Filter ?
    Take the idfle jet out and clean it. Then squirt WD40/carb cleaner (with straw attached) where you removed the jet from for about 10 seconds.
    Sep 2010
    I totally striped and rebuilt the carb from scratch with the proper webcon kit tho.
    However, on the articles section it says there is a rubber seal on the idle jet? My jet has no seal that i can see of ??!
    Would this really cause the idle to spaz out when i brake ?
    Non-member Shane P's Avatar
    Jan 2006
    Quote Originally Posted by xchipx View Post
    You need to have that O ring in place
    As far as i am aware, the only way your brakes can affect your idle is if you have a faulty one-way valve on the back of the inlet manifold
    Sep 2010
    But the handbrake isn't even connected to the servo unit because its cable/drum, and the idle prob only happens when moving
    Where is the O ring you mention ? I can not find a diagram of one anywhere
    Carbs always tend to get bits of swarf in them when they've been rebuilt, you certainly need the O-ring around the idle jet. If you haven't got one try some PTFE tape around the thread.....
    Sep 2010
    Note : the idle prob was there before i dismantled the carb #
    Thanks for that, so its actually the screw in thread that is where it needs a seal?
    I will go have a look.
    There was defo no seal on mine
    Sep 2010
    Thanks mate, have just put a seal on it - no difference sadly.
    Is the little bit inside the idle jet supposed to move around?
    Sep 2010
    The mix at idle is around 1.8λ so thats 25:1 AFR ( this might not be entirely accurate )
    That is perfectly stoich for methanol
    There must be an air leak ! ( Providing the gauge was accurate )
